Thread: Engine Wobble
    Aug 2010
    staffordshire
    Default Engine Wobble
    As above i have a wobble on the engine mainly when i start or stop the engine and vauxhall say the engine mounts are ok i know its weak mount but dont know which one. Has anyone had this issue.
    My car is a 1.9 cdti Cheers.
    Sep 2009
    Glasgow
    egr................
    Aug 2010
    staffordshire
    Hi m8 i cleaned the egr and i think it had a new one before i had it as the pin was shiny and new. The engine only wobbles on startup and stop like one mount is weak. I did notice that when we had the cold weather -10 the wobble went and is worse when weather is warm.
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    I have the same m8..so watching this thread carefully...when warm and you start it..it shakes like mad...cold in the morning doesn't do it...allthough sometimes it's hit and miss when warm...learning to live with it to be honest...but would like to cure if it possible
    Also if you sit with it on idle..rev it you can feel like the engines moving on the mounts...like a tilting affect back/forwards???
    Don't know if that's normal?
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    thought i read somewhere before an issue with the throttle body can cause a shudder when turning engine off, not sure though :/
    Oct 2009
    LINCOLNSHIRE
    Quote Originally Posted by Hideous View Post
    To be honest its more when starting when warm...
    Aug 2010
    staffordshire
    Yes mine does exactly this, its due to a weak engine mount but witch one? its hard to tell if they dont have damage. I think i may just replace both the bottom ones. I think they are around £40.00 each but its really annoying. Mine is getting that bad that i can feel it wobble on changing gear. It just spoils the car.
    Oct 2009
    LINCOLNSHIRE
    Has anybody got part numbers for the rear mount or mounts and price's?
  1. Wobble!
    By GoldenWonder in forum Suspension, Wheels & Brakes
    Last Post: 5th July 2011, 12:20
  2. bum wobble
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 18th May 2011, 12:47
  3. Engine Wobble
    By roco1970 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 21:43
  4. Wobble between 20 and 30 mph
    By Tigger in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2011, 00:28
  5. Engine vibration/wobble 3.0 V6
    By h00per in forum Engine & Drivetrain
    Last Post: 2nd December 2010, 21:24
