Results 1 to 10 of 16
Thread: Dension Installation - Help Required
    Regular Member Exclusive BV's Avatar
    West Midlands
    Default Dension Installation - Help Required
    Hi guys,
    Had a quick go at fitting a Dension Ice Link one tonight but had to give up.
    The Dension requires 3 wires to be fitted, A permanent live, an ignition live and a ground.
    Firstly I could'nt find an Ignition live on the head unit until i read on here there is'nt one, so i decided to use the one on the ciggy lighter.
    Question is how do i run the cable down there from the double din unit area?
    I removed the ashtray unit and gearstick surround but i could'nt get the oddments tray out.
    I just need to run the power cable from the area of the radio down to the ciggy lighter?
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    or all the way to the one for the backseats.. just as easy.
    West Midlands
    Yeah but i need to get the cable past the heater controls and oddments tray first and that's the issue.
    How does that tray thing come out? any ideas...............
    Engine : 2.2 Direct
    heater controls are just "pop out" the tray put your and in the tray and pust gently.. htey you sould be able to put it out.
    West Midlands
    Cheers, do you have to take them out in that order?
    Heater controls first and then tray or does it not matter?
    Engine : 2.2 Direct
    easist is tray first and then just a finger behind the heater controls, then that pop out.
    West Midlands
    Righto cheers for the help, I'll let you know how i get on in the morning with this
    West Midlands
    Ok KenP followed what you said and it all worked got the dension fitted but.....
    it's not working properly cheers for your help anyway bud.
    Not very happy this thing cost me £50 quid and i cant get a peep out of it
    Engine : 2.2 Direct
    Whats wrong with it...? it wont work without ignition on ..
    West Midlands
    Mate
    Your making the same mistake as me,
    Brown is NOT live it is Earth/Ground on a Vauxhall
    Like me you assumed that because brown is live on a 240v system it must be live elsewhere.
    I swapped the brown and black wires over and i was in business. Luckily i did'nt blow the thing up!!
  1. Dension 300 - USB interface for CD 70
    By donkmeister in forum Electrical & ICE (including SatNav)
    Last Post: 22nd September 2012, 00:33
  2. dension
    By scottyd in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2009, 16:31
  3. Dension ice link
    By andy1103 in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2008, 13:12
  4. Dension Ice Link
    By melomax in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2006, 16:53
  5. Dension Wiring
    By REDTi in forum Electrical & ICE (including SatNav)
    Last Post: 22nd May 2006, 18:40
