Results 1 to 10 of 14
Thread: please help
    Dec 2010
    beckenham
    Default please help
    hi guys i am getting very frustrated my 1.8 ls has a rough idle low mpg also when i stop at lights ect i sometimes get smoke from the engine bay if the heater is on it sucks the fumes into cabin smells like burning rubberish. had the car a few months changed front lambda censor when i first got the car but this week plugged in to friends reader it said egr maf both needed changing which i did no change.also yesterday changed thermostat car warms up now when driving still no change to idle today tried new coil pack still no change if i unplug lambda the idle gets better. if i unplug maf no change in revs .i only changed lamda cos the little emission light was on .could the lambda be faulty or do you think i may have another problem plese help.
    Nov 2010
    Vectra land
    could be spark plugs? how many miles u done, when were they last changed?
    Dec 2010
    beckenham
    Sorry I changed plugs in jan also cleaned throttle body
    Dec 2010
    beckenham
    Please anybody
    Jul 2009
    The Rift, Cardiff
    Could your egr be leaking? Spray some carb cleaner around the join with engine running, if has an effect on the idle it's leaking/sucking.
    Dec 2010
    beckenham
    I changed the egr and put the blanking gaskit from vauxhall on egr code is gone now
    Dec 2010
    beckenham
    Does anybody know what the black round thing is on the breathe hose that comes out of the back of the trottle body could this be blocked the hose is clear
    New Member cash1982's Avatar
    halifax
    if no change after unplugging maf that may be it...
    rough idle and low mpg usually means bad maf.
    May 2008
    Tyneside
    Could it be a blocked cat, especially with it overheating (burning rubber smell). I had a problem with a 1.8ls 2003, no egr fitted. http://www.vectra-c.com/forum/showthread.php?t=115545
    Check the flow out of the tailpipe, is it restricted. I unscrewed the lambda sensor before cat and ran engine, was noisy but tick-over was greatly improved and engine revved OK. Mine was getting so hot I could hardly touch the top slam panel. HTH
    Dec 2010
    beckenham
    Thanks For the replys so if I take out lamda 1 and engine runs ok then it's the cat blocked can it be unblocked or is it a new one
