Thread: Vectra C Interior Vents?
    Feb 2011
    Catterick garrison
    Default Vectra C Interior Vents?
    Hi, I have a Vectra C 2.2 Direct Sri XP. Could anybody please tell me of either a link URL of a site that can tell me how to remove the interior vents. On all 4 vents the bottom flap has either come of the rails or snapped not to sure. If anybody knows of a solution on how to recify this problem or the part numbers of the vents i would really appreciate it. I know it's cosmetic but i know the problem and have to have the vents open all the time to disguise the fault.
    Many thanks R.M
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Remove your dash trim, the vents are held in place by 2 screws at the bottom.
    Jul 2009
    The Rift, Cardiff
    easy to remove and easy to fix. Two of mine had the broken bottom slat. Once you've got them out you'll see the clips and tabs. Take it all apart so you're left with the slats and arms. Realign the flimsy arm for the bottom slat, spread a bit of super glue over break then put a thin strip of card on each side of the arm and soak with super glue. I tried with just glue but they broke again.
    Open the front doors (for ease & more room) pull the dash strip below the vents off.
    They are only a push fit, you will then see the screws as advised enabling you to remove the vents for remedial work of your choice hth ...............
  1. face lift chrome vents and rear vents
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2011, 21:13
  2. Vectra Air Vents
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 15:24
  3. Interior air vents
    By JoeMc in forum Bodywork & Interior
    Last Post: 15th September 2010, 13:37
