Thread: Airbag warning light constantly on
    Regular Member Winty's Avatar
    Feb 2011
    Surrey
    Default Airbag warning light constantly on
    A few months ago I had some hit the back of my 56 plate Vectra C Design, it went in for repairs and was all good, about 4 days after picking the car up the air bag light came on, I took it back and was told it was a low voltage on the driverís side curtain air bag, they cleared the fault and all was good.
    Yesterday I was just about to drive to work and the air bag light came on again, I have checked the driverís side connections under the seat like a lot of people have suggested but no luck.
    I went to disconnect the battery and found the negative terminal loose and could pull off with my hands (just slipped off). Could this be the cause of the airbag warning light coming back on i.e. low voltage sensed? Is there any way I can clear the airbag warning light? I was in the motor trade about 10 years ago but have lost touch with all my contacts.
    Any help would be much appreciated.
    Quote Originally Posted by Winty View Post
    Is there any way I can clear the airbag warning light?.
    Tech2 or similar fault code reading equipment.
    Feb 2011
    Surrey
    Dont suppose the loose battery could of caused the intial problem? Where can I find a reliable sorce for fault finding equipment?
    Feb 2011
    eastbourne
    There is a chance a loose battery terminal could put the air bag light on as it only takes a split second for the fault to log and light stay on. I would tighten the battery terminal then have codes read & re-set. If the fault returns it will need to be fault traced further
  1. emissions warning light on constantly.
    By Casper85 in forum Engine & Drivetrain
    Last Post: 2nd August 2012, 16:22
  2. Airbag light constantly on
    By Winty in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2011, 12:48
  3. Airbag warning light..
    By 46ross in forum Insignia car chat
    Last Post: 10th September 2010, 23:24
  4. Airbag warning light
    By supersione in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2010, 19:26
  5. Airbag Warning Light
    By Dthomas2301 in forum Engine & Drivetrain
    Last Post: 17th January 2007, 15:40
