Thread: on/off switch on CDR2005
    May 2006
    North Wales
    Default on/off switch on CDR2005
    My on/off swith seems to be broken and the unit is permanently on. This is not a problem as such as I can simply rotate the switch to to the volume to 'zero' to turn off.
    My problem is if the batterey is disconnected I will need to input the radio code. Does anyone know if this is possible with the radio 'on'? The manual says turn off radio before pushing the AS button before inputing the code.
    Any suggestions? or do I need a replacement unit! The car is a 52 plate and out of warranty.
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    a replacement unit is required im afraid,you need to have the unit turned off to imput the code as you have to switch the unit on with the ignition onand the as button pressed in,try ebay as there a few for sale on there
    Regular Member 2ltrT's Avatar
    North-East (Middlesbrough)
    you could have someone hold the as button while you connect the battery .
    May 2006
    North Wales
    Many thanks for your replies. - it is as bad as I thought, although Micks suggestion may be worth a try if it comes to it, otherwise ebay. I just had one more idea though - I believe ftom the manual I might be able to 'docode' the radio in its current state (on) and then if the battery were disconnected, it would not ask for the code and might turn on when reconnected? any thoughts?
    Thanks.
    Regular Member R-man's Avatar
    Beds
    Mike - I've had the same problem with mine twice recently after battery disconection for repairs etc. Take it to VX at the end of a day - I put it to them as "it'll just take two minutes if one of your lads can run out" - and they did. Having said that I found my unit would let me turn it on after battery disconection, even though it would never let me turn it off in normal situations.
    May 2006
    North Wales
    Thanks for your advice. No good worrying about it as the worst might not happen! I 'm having an oil filter/oil, fuel filter and spark plug change next week - fingers crossed.
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. Cdr2005
    By glenboy in forum Parts for sale
    Last Post: 22nd August 2009, 20:11
cdr2005 onoff switch
