Results 1 to 10 of 17
Thread: Please help code p0546 exhaust gas tem sens on 2.0t
    Regular Member vectra100turbo's Avatar
    manchester
    Default Please help code p0546 exhaust gas tem sens on 2.0t
    hi all i just had a diagnostic done on my vecta edition 100 i have the z20net engine in my car and it has come back with fault code p0546 exhaust gas temp sensor circuit high voltage or open circuit but i cant seem to find anything regarding this sensor does anyone happen to know what this code may mean and where i can find this sensor on my engine any info will be much appreciated
    thank you
    Nov 2010
    *!dave!* - The Black Country
    Sensor 1 bank 1 (so the sensor nearest the exhaust manifold)
    You have a wire that is getting a +ve voltage when it shouldnt be (refered to as short to positive) or EGT Exhaust Gas Temp sensor is faulty
    manchester
    thanks for reply but i dont suppose you know what may cause this wire to be receiving this +ve signal thanks
    manchester
    is this the sensoe that looks similar to a lambda sensor with 4 wires
    Nov 2010
    Quote Originally Posted by vectra100turbo View Post
    I would say it is most likely the sensor faulty
    But most sensors now are heated so a +ve feed could be shorting across to the sensor leads from the heater circuit
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    What year is your car as only 03-04 cars have the 3 x sensors on the exhaust system.If you follow the wiring loom to the left of the turbo you will find the plug in the loom.I think my sensor cost me £60 odd .HTH
    manchester
    Quote Originally Posted by Super T View Post
    hi my car is a 53 plate did you hae the same problem when you sensor went and did replacing it cure it i you did thanks
    Regular Member signumturbo04's Avatar
    SCOTLAND
    the egt sensor is at the bottom of the cat m8, if you look down the back of the block it looks like a lambda sensor but hslf the size and only has 1 wire going too it (had same problem lol)
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    you have the egt removed at remap time if your thinking of going donw that route...
    manchester
    i dont suppose anyone would know how to either test the sensor or bypass it to see if it eliminates the misfire issue or am i best just getting new one? only prob is no one seems to know what it is at any motor factors
  1. Fault code po403 exhaust gas recirculation valve.faulty.
    By Dobs in forum Engine & Drivetrain
    Last Post: 8th September 2012, 13:37
  2. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  3. Z22YH fault code 1191-5a (exhaust emissions?)
    By DaveG in forum Engine & Drivetrain
    Last Post: 3rd July 2012, 17:22
  4. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  5. p0031 & p0546
    By ephidor in forum Engine & Drivetrain
    Last Post: 8th September 2010, 15:43
p0546 vauxhall
p0546 opel
vectra p0546 codep0546 vectra cz20net supape unisensp0546 fault code after egr blankingp0546 2.0t egtp0546 opel egtvaux signum exhaust gas temperature sensor problemscode 0546 vauxhallwhat course car code p0546p0546 fault code on vectrap0546 vectraz20net exhaust temperature sensor
