Results 1 to 10 of 18
Thread: Hub Changed
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Hub Changed
    Took a good 2 1/2 hours with a proper trained mechanic watching over me and helping when needed.
    Don't know if it is usual but the old one crumbled when it came out
    New one on (eventually), plugged in and no more ABS / TC warning lights! MOT here I come!!
    Word to the wise though - I was in a working garage with mechanic's to hand and their full plethora of tools and it took a good while! Best not to attempt this on your driveway if you are a novice!
    On a side note - I need to get me a windy gun!! Took the strut off without one in about 20 minutes - with one and it was about 20 seconds!
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    Quite well possible on the driveway as I did but you do need to be moderately set up to do it.
    Tain - Easter Ross
    Hardest bit (for me) was getting the new one in, lived up and with the driveshaft in position. And I did say 'novice' - maybe I should have defined!
    Just glad it didn't need tech2'ing to sort the lights.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    Fair play for trying must be quite daunting attempting something like that for the first time
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    im waiting for a front hub to be delivered atm thenas soo as it arrives (they say it will be between 2 and 3) ive gotta go fit it ready for my dads mot tomorrow, could be a long night lol
    May 2008
    Tyneside
    Did a front bearing recently, hardest job was removing the driveshaft. Had to use a puller to get the splines off.
    May 2006
    Mansfield
    Default A Quick Question for an Expert
    Quote Originally Posted by tridley View Post
    I need to do my front left one soon as it's making some rather funny noises, can you tell me when you apply the hub puller which part moves? does the drive shaft move back out of the hub or does the hub/strut swing out ?
    Many thanks in advance
    SJ
    May 2008
    Tyneside
    The driveshaft moves out of the hub. Obviously you have to disconnect bottom suspension balljoint to enable the hub come off. HTH
    May 2006
    Mansfield
    Many Thanks
    SJ
    Tain - Easter Ross
    I didn't undo my ball joint, I took the strut off the hub (maybe the upside down way of doing it?)
    Just remember to not let the driveshaft come out of the gearbox
  1. Changed my car
    By wolvesdaz in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2012, 19:48
  2. CIM CHANGED NEED TECH2 in OXFORD AREA HAS ANYONE CHANGED A CIM BEFORE?
    By vectrasimonsri in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 20:43
  3. can these be changed>
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2010, 20:47
  4. how much has your car changed since you had it
    By tonyt in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2008, 15:21
  5. My Name Has Changed
    By 3.2_V6_VXR in forum General Chat
    Last Post: 18th July 2007, 04:37
