Thread: front fog lights
    dunfermline
    Default front fog lights
    Hi can anyone tell me if i can fit vauxhall standard front fogs to my 06 signum elegance?
    does any one know if it can be done due to the can-bus wiring? will the wiring be there or not??
    cheers garry
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    hi m8
    yes you can do that no problem,you will have to get a light switch that
    has the front foglamp switch on it,you should have the wiring already
    there as i fitted fogs to a vectra and his was an elegance and his wiring
    was taped up behind the bumper each side.
    your looking for a blue plug on each side,oh you will also need it
    programming to activate them.
    if you haven`t got the wiring then it can be retro fitted which is easy enough
    Chelmsford
    Thought Elegance models always had fogs as standard...
    Mine has but it's an 04 plate pre-facelift.
    dunfermline
    not sure about elegance having them as standard but seen another couple of facelift elegance signums and none have them fitted?
  1. front fog lights
    By steve19cdti in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 20:57
  2. Led H3 front fog lights
    By bobssignum in forum Styling
    Last Post: 8th May 2011, 17:15
  3. Front fog lights
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2011, 13:37
  4. Front fog lights.
    By VectraGezza2010 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 21:44
  5. front fog lights
    By dcdevlin in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 18:21
