Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Does Anyone stick to recommended tyre pressures?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Does Anyone stick to recommended tyre pressures?
    I usually put a few pounds extra of pressure in, and after talking to a few people so do most others, and also whenever I have had tyres fitted, they always put a lot more PSI than the VX recommendation?
    Any thoughts on this?
    The handbook recommedations just dont seem enough?
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    40 in mine and thats fine by me
    swansea
    Do you also put in too much coolant, and an extra litre of oil. Do you think manufacturers just pluck tyre pressure figures out of thin air. Stick to recommended pressures, it's safer and your tyres will last longer.
    Sep 2010
    in a box
    yes no just like 100ml they mite be there but i use what psi i think is ok for tyres im running 18s on low tyres so 40 is fine
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    got 36 in my 18's and they still look half flat
    Sep 2010
    in a box
    Quote Originally Posted by TimTay View Post
    i done 35 looked flat running 40 seems fine plus saves my alloys a bit
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    yes, i put the correct amount in.
    why compromise safety by filling them wrong
    11 Post(s)
    Book says 32 psi all round, and that's what I've set them at. No unusual signs of wear on any of the tyres.
    Oct 2007
    south wales
    This all started me thinking because I always had a manual tyre pressure, and the readings were never that great, and the forecourt pressure hose guages are legendary for beinh inaccuarte, so I forked out for a digital guage which is great, but if I stick to the recommended pressure , the tyres look flat...
    29 for front, 32 for rear...
    Sep 2010
    in a box
    Quote Originally Posted by PeterVV View Post
    thats why id say most run higher psi i ran 40 in my std wheels and were fine
  1. Tyre pressures
    By Corey in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2012, 10:03
  2. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  3. 225/45/17 tyre pressures?
    By rosssri in forum Handling & Braking
    Last Post: 15th September 2008, 16:56
  4. Tyre Pressures?
    By maz in forum Suspension, Wheels & Brakes
    Last Post: 12th September 2008, 17:41
  5. Tyre pressures...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 20:25
astra j eco or comfort tyre pressure
