Thread: Cd70 Navi Cd Fault
    Regular Member toughmat's Avatar
    Home Rhondda , Work in Cwmbran
    Default Cd70 Navi Cd Fault
    I Picked up the car last week and so far so good, except there is a disc jammed, and it will not eject, i tried putting another disc in and tried to trick it but it didn't work.
    Do any of you have any pointers??
    Matthew
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    If you can drive to glasgow then i would give it a try.
    but how would you manage to get it out ??
    Jul 2010
    Scotland
    You have to open it to get the disc out. Generally the doggy belts in the cd drive cause the problem
    Regular Member LJ sxi-nav's Avatar
    Winchester
    I had this problem - when the unit is on does it register and play the stuck CD? mine did and I solved it by partly inserting a new disc, then as the motor kicks in to suck the disc in the drive I snatch it out. This fooled the unit in thinking a disc had been inserted, and happily ejected the original disc.
    Or you could try the cd sandwich trick that was suggested to me - try and partially insert a couple of old/blank discs in the drive, above and below the one that is stuck, then try gripping the visible part of the 2 discs and pulling. Can be quite tricky as I think discs go in and down into the drive.
  1. cd70 navi help
    By aidy-cdti in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2011, 08:16
  2. CD70 navi fault
    By mky82 in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2011, 22:15
  3. CD70 Navi
    By 1.9Cdti Elite in forum Electrical & ICE (including SatNav)
    Last Post: 30th August 2009, 08:50
