Okay folks, to avoid opening new thread on what might be simple issue, here goes my trouble:
Bought 2008 Estate 1.9 CDTI 120 two months ago. It's been running sweet ever since except for a small hick-up that started occurring for last 7ish days. What happens basically is as car accelerates in low rpm, i can feel a slight jolt as if it lost power very briefly (less than a fraction of a second) and then it continues working and performing flawlessly for the rest of the drive... It's literally a fraction-second loss of power that got a wee bit worse today and actually happened twice on a 20km drive... Happens usually around 2K rpm...
Now, I have been reading stuff about injector wiring (it's 120, not 150?), egr valve cleaning, boost sensor cleaning, clogged up DPF (yep, i have it, but also have long streaks of road where i can literally floor it it make filter breathe). I also have OPCOM handy, but it doesn't show any errors. I thought it was AC compressor kicking in (that's how slight the hick-up was) but as i said, it did it twice today and it was much more noticeable... Where should I start troubleshooting?
vac pipes maybe fella or even tho u have cleaned the egr it could still be the problem i know alot of people have blanked their egr off as i did it yesterday try unplugging the egr and take it for a run see if it cures the problem if not try the vac pipes
10th June 2014, 10:15
#33
Hi, se as above to avoid a new thread on the same issue, egr on mine has clogged as per my breakdown service and the computer he plugged into the car. Got it in today to be looked at however now looking at blanking it. Found a plate and gasket on eBay for the square end but then been reading need to block the other end too, is this true? Also I am getting one with holes in so as to avoid remap at the moment as cannot afford extra cost as currently got to replace a lot of front suspension etc will this do the job or do I need to pay the extra out now for the remap?
thanks
30th March 2015, 12:07
#34
VX Vectra 1.9 CDTI 150 56plate.
Hi I am pretty sure the below issue will sort mine, so will give it a go.
Last week or so everything under 2000rpm has been flat until turbo kicks ins and car runs fine. DPF has been re-gen and no fault codes, so hopefully below will work. I did also think Air Mass Filter, but no error codes or warning lights.
Any advance on below please let me know.
1. Egr valve sticking or stuck. Symptoms are poor acceleration and possibly black soot out the exhaust also rough idle and no power below 2000rpm
Remedy. Clean or replace egr or blank egr
Links to assist here.
http://www.vectra-c.com/forum/attach...7&d=1232829228
Cheers Dan.
Reason: Car Type
29th April 2015, 15:40
#35
just joined and already loving this site so much easier to remedy the veccys problems ace work and thanks for taking the time to write it all down nice one
26th January 2017, 18:00
#36
Please somone help,
Took me 1.9 150 to get the alternator pulley done as everyone i know has said the squeeling is down to that so had it changed and still squeeling they have said its the turbo but its not smoking bad it runs fine but as the power gets layed down the turbo on me turbo guage flutters untill i let thw power off
Can somone knock this on the head before i go mad and break it and sell in parts that i really dont want to do
Sent from my SM-G935F using Tapatalk
19th March 2017, 22:03
#37
New vectra owner 1.9cdti Exclusiv .i have a light engine smell coming through heater when stationery
So whenever im sitting at lights i notice this exhausty smell coming through heater . a hear people talking about EGR valve dunno if anything to do with it?
also one other thing my driver side headlight fogged up i want to change it.
thanks
19th March 2017, 22:41
#38
Originally Posted by
Craiganvec
thanks
The fumes could be coming from a worn flexi on the exhaust which seems to be the most common cause. A few days ago I discovered a small leak on my vacuum pump that I'm hoping a new gasket will sort and put an end to the fumes in the cabin.
19th March 2017, 23:04
#39
is the flexi underneath , ramp needed?
19th March 2017, 23:51
#40
Craiganvec
Yes and yes, unless you are very small
Post Thanks / Like - 1 Thanks, 0 Likes
