Thanks Thanks:  1
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: All common symptoms for 1.9cdti look here before posting thanks
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default All common symptoms for 1.9cdti look here before posting thanks
    A few tips for the same old common questions we see so have a read here 1st I am Trying to help every one with the cdti 150 and the 120 with a fee common issues to be checked I your experiencing lack of power and juddering etc
    1. Egr valve sticking or stuck. Symptoms are poor acceleration and possibly black soot out the exhaust also rough idle and no power below 2000rpm
    Remedy. Clean or replace egr or blank egr
    Links to assist here.
    http://www.vectra-c.com/forum/attach...7&d=1232829228
    Dpf blocked up (if you have one. Automatics, estates, all signums. You will have a 0.5 on your drivers door sticker where your chassis number is if you have a dpf.)
    Symptoms. Are lack of power through out the rev range, poor mpg and in extreme cases engine won't start and eml on.
    Remedy, try cleanin your dpf if no succeeds then either replace dpf (expensive) or remove the insides then refit and get the software removed from the ecu by means of a remap.
    http://www.vectra-c.com/forum/showthread.php?t=129911
    Vacuum boost pipes split. Symptoms are lack of turbo and poor performance. Remedy. Check pipes for splits and replace with upgraded ones or new ones from Vauxhall
    http://www.vectra-c.com/forum/showthread.php?t=109454
    Swirl linkage not on. Symptoms poor performance sometimes and also some go unnoticed. Remedy check bar and try the diy fix or in the end buy a new manifold expensive but will cure faults and increase power and mpg. To prevent future failures you can semi blank egr and vent oil system to atmosphere
    http://www.vectra-c.com/forum/showthread.php?t=33511
    http://www.vectra-c.com/forum/showthread.php?t=121315
    http://www.vectra-c.com/forum/showth...ght=Catch+tank
    No3 injector, symptoms are juddering and a slight misfire in extreme cases un driveable with eml on sometimes, remedy replace no3 injector wiring
    http://www.vectra-c.com/forum/showthread.php?t=73584
    Mods if you can make this a sticky would be a great help to everyone and save alot of repeated posts
    Also if anyone else has any common faults then please add on to this in the same format with links and symptoms etc as this will help everyone thanks again
    kings lynn, norfolk
    Throttle body intermittent problem or stopped working
    Symptoms, Juddering and also engine management light on not always with codes relating to throttle position. Remedy is resolder the circuit board or remove your throttle plate to see if that eliminates the problem
    Links
    http://www.vectra-c.com/forum/showth...45#post1338145
    http://www.vectra-c.com/forum/showth...throttle+plate
    http://www.vectra-c.com/forum/showth...=118784&page=2
    Regular Member corderz's Avatar
    Bradford
    good idea winnie
    kings lynn, norfolk
    Cheers it saves all the same posts and ppl asking where is the link to this and that etc any more probs or common issues then feel free to add to this thanks guys
    Nov 2010
    *!dave!* - The Black Country
    Why not start a website
    www.1001-things-to-go-wrong-with-your-diesel-150bhp-vauxhall-lol.com
    Well it does have a certain ring to it - lol
    Regular Member Craig1985's Avatar
    harwich essex
    Great thread, sure people will still post the same old threads, hids, milage, tyres , erg, inlets hmmmmmm
    Regular Member Mopar Man's Avatar
    herts
    Nice.
    stockport
    Arrow
    Quote Originally Posted by RS2000CUSTOM View Post
    I clicked on to it like a prat!!!!!: FELIXX.
    Regular Member Diesel Dude's Avatar
    Norfolk
    Nov 2010
    Quote Originally Posted by felixx View Post
    Quote Originally Posted by Diesel Dude View Post
    Now that really is funny - lol
  1. P0100 most likely cause for these symptoms
    By brotherkennyh in forum Troubleshooting
    Last Post: 16th November 2012, 22:16
  2. Replies: 6
    Last Post: 9th June 2012, 10:38
  3. EGR symptoms
    By tobybongo in forum Engine & Drivetrain
    Last Post: 12th October 2008, 21:32
  4. dmf symptoms
    By tommy tess in forum Engine & Drivetrain
    Last Post: 30th May 2008, 21:14
  5. Symptoms Of Being Over 25…..
    By Inspektor in forum Comedy & Humour
    Last Post: 22nd February 2006, 15:47
astra 1.9 cdti egr valve symptoms
vectra egr valve symptoms
symtons of egr and dmf problems with vectra cdti
vauxhall astra 1.9 cdti sri 2012 egr valve problems
http:www.vectra-c.comforumshowthread.php130008-All-common-symptoms-for-1-9cdti-look-here-before-posting-thanks
vectra c egr valve symptoms
astra 1.9 egr problem symptoms
vauxhall astra 1.9 cdti egr valve symptoms
vauxhall astra 1.9 cdti sri 2012 egr valve symptoms
astra cdti 1.9 egr solenoid serving
2011 astra vauhall sri dtci 1.9 egr
