Thread: newbie question
    Wishaw, Scotland
    Default newbie question
    my engine management light has come on and iv noticed a loss in power any ideas?
    vectra c 1.9 sri ctdi estate 78k 08plate
    quality site iv been looking around here for a while now and its one of the best forums iv been on..
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Scott c View Post
    The lack of power with the Engine Management Light on is known as "Limp Mode". Basically, the power / rev range is reduced by the ECU when a fault is detected.
    If you know anyone with a fault code reader, try and get 'em read. Will point you in the right direction
    Wishaw, Scotland
    Thanks for your help i will look into at the weekend thanks again for the fast replys the oneS in the link would they put the light on?
    Scott
    kings lynn, norfolk
    Yup they can all put light on you really need ringer the codes read
    Wishaw, Scotland
    Thanks ill try and get that done at the weekend.
    Scott
    Jan 2010
    wirral
    From my own experience, I wouldn't mind betting it will be DPF related, but you never know!!
    Wishaw, Scotland
    Hi guys the code reader has come up with a P2279 intake air system leak any ideas???
    PRESTON
    Sounds awefully like a DPF blockage, it has been seen several times on the estate 1.9 cdti's. Best course of action is firstly to remove and back jetwash the dpf then refit and see if it improves anything.
    Jan 2010
    wirral
    Is that code not "swirl actuator" related, I'm sure I got that when I tried the £1 fix.
    After re-fitting the swirl rod and going for a run, I seem to remember getting EML (not car/spanner) along with the 2279 code.
  1. newbie asking newbie question :-)
    By gavatron in forum Engine & Drivetrain
    Last Post: 6th February 2012, 10:39
  2. Newbie question
    By mikey2704 in forum General Motoring Chat
    Last Post: 23rd January 2012, 14:30
  3. Newbie with a question
    By AlexGSi2000 in forum Introduce yourself.
    Last Post: 1st May 2011, 18:06
  4. Op-Com newbie question
    By Xerath in forum Troubleshooting
    Last Post: 3rd August 2010, 21:31
  5. Newbie question about BC
    By TonyVectra in forum General Chat
    Last Post: 18th December 2008, 23:30
how to fix an intake air system leak vauxhall zafira 1.9sri
