Thread: 2.0dti help needed
    Sep 2010
    manchester
    Default 2.0dti help needed
    last few days its being a right ****** to start , 1st turn of key it starts first go, then it cuts out strate away , 2nd turn for 20 seconds nothing , 3rd turn 20 seconds it springs to life, thats it then fine until next morning and same, its had new glow plugs fitted.
    any one have any theories or come across this before?
    thanks for any advice any one can give.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Have you tried putting some cleaner through the injectors , try some 10k boost or another injector cleaner if this does nt solve anything try changing the fuel filter
    and still loving it
    Sep 2010
    manchester
    fuel filter changed already..... possible for the leak of pipes or injector seals to cause this?
    Engine : 2.0DTi
    Mileage : 73350
    I am not certain on this let some one else come in on this ,
    Anybody else any ideas on this .
    and still loving it
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Park it up pointing down hill. See what happens the next day. If air is getting in at the injectors, then you shouldn't have much of a problem starting in the morning. If the car is pointing up hill, the fuel can run back to the tank.
    Sep 2010
    manchester
    thanks mate. its all level on drive and street.... just backed it onto a piece of 4x2 lol so it is pointing downhill just hope its enough lol.......
    thanks for the pointer much apreciated.
    north east
    have a look at the injectors,if it is wet or overlyclean round them the leak off pipes need changing.
    crank shaft sensors are also known to cause you needing to crank and crank and crank the engine to get it to start ( about £40 for a new one and hel in with 1 torx screw )
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    This happened to my dti I just lived with it the sold the car a month ago
  1. help needed to fault find (or read codes) 2.0DTi
    By FLOB in forum South East (RO - Scotty80, ARO jaqubek)
    Last Post: 4th April 2012, 18:15
  2. Help needed!!! Glow plug lead removal 2.0dti
    By FLOB in forum Diesel Engine related
    Last Post: 17th March 2012, 18:24
  3. 2.0dti Diesel pump advice urgently needed
    By ads3 in forum Diesel Engine related
    Last Post: 14th June 2011, 15:33
  4. Help - can anyone with a 2.0DTi help?
    By evsy72 in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2007, 14:54
  5. 2,0dti CAT
    By dervdoc in forum Parts for sale
    Last Post: 2nd May 2007, 14:43
