Thread: Snapped Wheel Stud
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Snapped Wheel Stud
    My front n/s wheel has a snapped wheel stud. This must have been like this before I bought the car since I found out after having the tyres changed, on inspection someone's attempted to drill and extract it, but obviously didn't get anywhere.
    Now although it's been fine on four studs for sometime I do want to fix this properly. The stud is snapped inside the disc so I'm hoping if I take the disc off there'll be enough stud sticking out the hub to weld a nut on and give that a go (a guy at work is willing to try this for me).
    However, if this doesn't work or there's not enough stud poking out to get welding to, what will my options be? Is the hub/flange or whatever an expensive bit of kit to buy and is it easy to fit?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    A front wheel hub is only about 70 odd quid. If you cant get it out with the disc off i'd personally just replace it. It's alot less hassle
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    to be fair once the weight is off the bolt ie:wheel and disc and just the stud in the thread I would think with a bit of lube or heat it would come out easy but saying that why did the previous owner not remove it? can you not get a second hand hub and just swap it over while you have it striped
    Chelmsford
    Pick up a set of Easy-outs...
    http://cgi.ebay.co.uk/5PCE-DAMAGED-B...item19c2e690d7
    Wouldn't have thought it would be too hard, especially with a bit of heat, or a freezer spray.
    Alternatively, if there is a enough left with the disc off, grab it ****** tight with some mole grips.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    theres a pair of grip pliers cant think what there name s they would work
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    vicegrips
    Regular Member chrisknights's Avatar
    Feb 2011
    brighton
    some how i lost my locking wheel nut key , so i drilled in the center with a 6mm drill bit and went it about 10mm and then got a torq star bit and tapped it in the 6mm hole and then used a socket to undo it and it worked for me ,
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by DNS View Post
    sorted mine on my renault.
    Apr 2009
    Stevenage, Herts
    Thanks all for the replies, I've only just got back on the net to view these.
    I have an extractor set so maybe try that first, heat and freezer spray and see how it goes. Think I'll do it Thursday night as at work overnight without much to do.
    I'll let you know how I get on!
  1. Snapped exhaust manifold/turbo stud snapped in cylinder head!
    By XPCobra in forum Engine & Drivetrain
    Last Post: 7th May 2012, 10:50
  2. alloy wheel centre caps 5 stud
    By mitch in forum Parts for sale
    Last Post: 28th July 2010, 21:43
  3. alloy wheel offset and stud pattern!
    By veccy22 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2007, 12:52
  4. Wheel stud diameter advice
    Last Post: 30th January 2007, 22:45
