Results 1 to 10 of 19
Thread: Fan Problem..... Dont work on 1,2,3 but works on 4...?
    Feb 2011
    West Sussex
    Default Fan Problem..... Dont work on 1,2,3 but works on 4...?
    Hi all,
    just a quick question, i dont have a vectra as of yet...
    but im hoping to look at one at the weekend... the add seems ok and reasonable price, mileage, full service history.
    Just one thing im warey of is in the ad it says :
    " THE HEATER HAS STOPPED WORKING ON 1,2,3, BUT WORKS ON 4. I"VE BEEN TOLD ITS A COMMON THING ON VAUXHALL'S AND IT'S THE RESISTOR. WHICH IS NOT ALOT TO FIX "
    Just wondered if it is a common problem on the C's? and if it is a cheap & easy fix?
    Thanks, John
    Mileage : 000
    If you do a search on here there is loads of information about this problem.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    As said loads of info on here. Thing to check is for water in the passenger footwell which will come from a blocked drainage bung under the scuttle tray. Rain water will then come in through the pollen filter and kill the resistor pack for the fan, and evenutally the fan itself if left too long (as my mate found out).
    Easy & cheap fix by all accounts.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    82p if your handy with a screwdriver 25 quid if your not
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Resistor pack, deffo
    Do a search on here for threads started by "ijg" for the blower motor one, then move to page 3. Simple to do
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    this is what you want this fixes it
    common fault
    it happens a lot on the forum
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item3f074df6d9
    remove the glovebox
    http://www.vectra-c.com/forum/showthread.php?t=108462
    its a the bottom
    just slot the resistor pack in
    also could be the relay but try above first
    Regular Member djr69uk's Avatar
    Midlands
    Quote Originally Posted by tony-1977 View Post
    Not neccessarily defo... could be a relay, as was the case with mine. However, as said previously, cheap and easy fix - so don't let that put you off at all
    Aug 2010
    Luton
    its not relay if it works on 4
    stockport
    Thumbs up
    Quote Originally Posted by djr69uk View Post
    If it is the resistor.....£25+from VX,or just buy a new thermal fuse from Maplin's,82p,....results,?.....Priceless!!!. FELIXX.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    is there a how too on replacing the thermal fuse
  1. HELP! Dials on dash dont work
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2016, 18:04
  2. Brake lights work then don't then do then dont
    By Wetdude in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2011, 16:40
  3. front fogs dont work
    By lops01 in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2010, 04:05
  4. No fans, 1, 2 , dont work?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2008, 21:02
  5. Fitting Sxi Fogs To An Ls There In But Dont Work
    By dadstaxi in forum Electrical & ICE (including SatNav)
    Last Post: 7th September 2006, 15:01
