Results 1 to 10 of 11
Thread: Bulb trouble!!!
    Aberdeen Scotland
    confused Bulb trouble!!!
    Hi I have the bulb warning symbol on and all my lights are working fine. Its been on a while now and i want to get it sorted. Reading the manual and a few searches on here suggests that it is warning light that a bulb is about to go and also that a bulb has went but the use of that bulb has been switched to another bulb. So where should I start. The rear lights is the brake light the same bulbs as the side and head lights. As i checked this last night and it was on the same level on the rear cluster for both. I have a signum 3.2 v6 year 2003 if this helps any ideas thanks???
    Regular Member v6diesel's Avatar
    Southampton
    Does the message not tell you which bulb is at fault?
    Aberdeen Scotland
    no just the bulb symbol with an ! through it
    Blantyre
    Are you sure the rear bulbs are all working and both sides line up
    If one goes there is another that kicks in underneath ?
    Aberdeen Scotland
    they are definitely coming on at the same levels but as i said the brakes are the side and main lights also on the rear so is this correct or should they be on different levels?
    Blantyre
    No sounds ok,
    Could be that there is one on its way out also, veccy is clever that way
    Aberdeen Scotland
    is it possible to know which one? Rear or front?
    Blantyre
    I would try the rear bulbs first,
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you checked all foglights etc?
    newport
    i had that on one of the rear lights, turn your headlights on and you will probably see one is taking power from a different bulb
  1. Dnf trouble
    By Ruffus2 in forum Engine & Drivetrain
    Last Post: 5th August 2012, 09:29
  2. Am I In Trouble??
    By Mattle40 in forum General Motoring Chat
    Last Post: 27th January 2012, 22:40
  3. Car Trouble
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 12:43
  4. Can I Replace Fog light Bulb for a 100 watt Bulb
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 19:33
  5. Air con trouble
    By mikec in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2009, 10:32
vectra c light bulbs troubes
