Thread: Ebay CD70
    Regular Member leonvectrac's Avatar
    south shields
    Default Ebay CD70
    After a brief talk with bigmac and he suggested that a cd70 navi with cid should be a striaght swap into my 2005 full canbus vec. If i bought one from ebay, it should as they say in the add be "plug and play if fitted together" but most dont have sercurity code with them, so are no good without it are they?
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    I bought a CD70 and its CID from the bay and shoved it into my 2005 full canbus siggy, it came without a code. I have installed and removed a few vauxhall stereos in my car and all have worked straight away. Firstly, it went straight into the car and worked immediately (no tech2 required, so ignore that useless advise when you get it), secondly i have since been messing about with it using opcom and never needed the 'radio code'. I have taken it apart to add the aux in function and upgraded the firmware as well, its never asked for a code...
    south shields
    Quote Originally Posted by Caveman_nige View Post
    Hmmm, thats interesting to know. Will i have to buy a new aerial for the sat nav to work?
    Jun 2009
    South Coast
    when you take out your old stereo have look behind to see if you can find a wire with a blue plug/connector on the end this will be the gps antennae. If you do not have one of these in the car the you by a fakra gps antennae from ebay, this will have the blue connector to plug into the back of the CD70 (a blue socket), ther fakra will have about 2 metres of cable leading to a black block about 5cm wide and long, this is the gps antennae, you feed this somewhere under the dash to a spot where you get a signal. Many have done this with the fakra. Just be sure that any CD70 and CID you buy comes with the RGB cable as this is the one that supplies the maps/navi to the screen.
    south shields
    Have you got a link to the one your talking about caveman please? and thanks for your help, much appreciated.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It's funny that because when I tool my cdr2005 out of my old Vectra it needed a Code but the other day I took my ncdc 2013 out if my signim and didn't need a code
    Full Member
    South West
    With regards to buying without a securtiy code, the only time i need mine was when i had the bluetooth installed. Prior to that, it was just plug and play.
    Should you need the security code in the future, it is possible to have it read.
    This is the GPS antenna you will need if you dont have the connection already:
    http://cgi.ebay.co.uk/GPS-ANTENNA-FA...item5640f8db4f
    I bundled the extra cable up, and put the antenna where the centre speaker goes. Fixes on the sats everytime in that position.
    Rgds
    Aidi
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    If you can read the VIN number from the screen using Op-Com, Vaux-Com etc you can then go to VX and get the code should you ever need it, plus it would then allow you to marry it to your can and use the your current code.
    VX will charge you about £30 for this.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by paulvectrac View Post
    Because the CDR isnt coded to anything, where the NCDC is coded to the car/screen.
  1. cd70 screen on ebay what elso do i need?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2008, 19:44
gps antenne opel vectra v6 3.0 cdti
