Thread: Vectra c transponder problem help needed!!!!
    Feb 2011
    Sheffield
    Default Vectra c transponder problem help needed!!!!
    Hi all,
    I need some tech help please, got a vectra c 2.2 petrol, and the transponder around the ignition barrel has got damaged inside, so obviously the car now won't start! So I'm going to attempt to solder ithe 2 metal connectors to the transponder back on, an what i need to know is will the transponder need recodeing?
    And also if I get a new steering wheel column with the transponder in it, will it need coding in?
    Thanks!
    Nov 2010
    Vectra land
    hello mate, pretty sure it wont need re-coding although if u were to put a second hand one on you will need to get it coded.
    Nov 2010
    *!dave!* - The Black Country
    If all you are changing is the code reader "coil" that goes around the ignition barrel area then no re-coding will be required as the key "chip" will still be recognised by the immobiliser ECU
    Soldering the wires may actually work so worth trying first anyway
    dunfermline
    ashe said above the transponder is just a reader and doesnt need coded. it only reads the code and sends on the information.
    Feb 2011
    Sheffield
    Brilliant, thanks alot, so even if I replace the coil, it still won't need recoding! Yr gonna try n solder it first tho, try n save some cash, just means taking the steering wheel off, but suppose it's not too big a job! Thanks again!
  1. Auto airbag transponder help needed
    By Dannyboy444 in forum Electrical & ICE (including SatNav)
    Last Post: 30th August 2012, 03:28
  2. How to remove transponder on new vectra key?
    By smiley-sri in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2012, 20:07
  3. Vectra C Transponder ?
    By 3.2wales in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2009, 01:02
  4. Key / transponder / remote problem...
    By danncus in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2009, 17:11
  5. Key / transponder / remote problem...
    Last Post: 26th July 2009, 16:36
