Thread: No power!
    West Yorkshire
    Default No power!
    Bizarre one here - maybe something simple?
    1.9CDTI 150 with upgraded Vacuum hoses (4mm ones), Airbox mod and K&N, 10kboost last weekend, Boost Sensor cleaned last weekend.
    noticed been running a bit sluggish in past week after doing work above, doing new EGR this weekend, but plugged DTUK box in this morning and was flying but then started to notice sluggishness low down in revs.
    Went over a bump (maybe coincidence) and now reallllllly slow and sluggish - no warning lights on....
    Any pointers on things to check??
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Is yours a hatchback and not a automatic, signum, or estate as could be dpf clogged up but if you have a manual hatchback then won't have one
    Sounds like egr couk be sticking open a bit
    Or could be no3 injector
    Also could be your swirl valves so check your inlet manifold
    There are loads of threads on here about the above so do a little search and see what you find
    kings lynn, norfolk
    West Yorkshire
    Quote Originally Posted by winnie2457 View Post
    Excellent Link mate - good work
    Done the 3rd injector a couple weeks back after it went potty on the motorway - garage soldering connection in morning.
    New EGR has arrived, not sure whether to use the Fiat semi blanking gasket or not.....
    Had new manifold done by Vx prior to me buying car (approx 80k, now on 116k)
    Hopefully its the EGR - sounds like it as it's become intermittent today.
    Thanks!
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Quote Originally Posted by hebdendave View Post
    check your box hasnt come loose, also disconnect it and try without
    West Yorkshire
    Well well, just replaced egr valve and car running sweet! Dtuk box back on and it's like a train!
    original egr is so clogged up it's unreal, going to clean itt up and keep as a spare.
    cheers to all for all the helpful info on the site! _
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
