Thread: Changing power sounder and its loctaion (In a Signum)
    Engine : 1.9 CDTi
    Default Changing power sounder and its loctaion (In a Signum)
    Where is the power sounder on the Signum and if I got a new one can it just be swapped over or does it need coding to the car?
    Oh and will a Vectra one be the same?
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    its in the back on left hand side mate near fuse box ***** to get to and if un plugged it works off the horn
    Engine : 1.9 CDTi
    Why is it hard to get too?
    I have the safe guard warning and it says the power sounder has no communication so its probably got flat battery's.
    11 Post(s)
    Quote Originally Posted by lee gsi View Post
    To make it more difficult for a thief to get to I would imagine.
    Engine : 1.9 CDTi
    Why as in whats in the way that I will need to remove?
    11 Post(s)
    Its right by the fuse box in the cubby hole and access is limited.
    Regular Member neilb1's Avatar
    Feb 2011
    wigan
    my alarm went of the other day and sounded like a wimp of an alarm ?
    Chelmsford
    Vec C/Signum alarm is RUBBISH!
    Seriously, total crap. Been wondering if there was a way to sort it for ages
    Jul 2009
    The Rift, Cardiff
    Its actualy very loud when its going off in your hands. The ideal solution would be to add a second siren under the bonnet, but i'm yet to hear of a way to do this, as moving the siren from its secure location could invalidate your insurance.
    If it's the same as the vec it's best to remove the bracket too, as uncliping with such limited space is likely to draw blood. Disconnecting the plug on the back is also difficult while it's in place, but the wire is short so take care.
    Engine : 1.9 CDTi
    Will a replacement need to be coded?
  1. Power sounder problem
    By namalundu in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2013, 22:02
  2. 3.0 V6 CDTI - Loss of Power/Changing Engine Map
    By a18nmk in forum Engine & Drivetrain
    Last Post: 29th March 2011, 20:57
  3. Power sounder batterys.
    By suggs1971 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2011, 20:38
  4. Power Sounder
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2011, 10:40
vectra c how to change power sounder site:www.vectra-c.com
