Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Thread: Save Yourself £1200 + vat DPF Clean Up !
    Nov 2010
    *!dave!* - The Black Country
    Default Save Yourself £1200 + vat DPF Clean Up !
    In reference to this thread - http://www.vectra-c.com/forum/showthread.php?t=129663
    Here is a nice little tip to save you all a lot of money
    If you suffering from a goosed DPF filter then
    Remove it
    clean it with a pressure washer
    Refit it
    SIMPLES
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    or just smash the moter out of the insides and sorted for life. i looked at doing this but was no way it was going to work on mine mine was jammed good
    Nov 2010
    It took apprx 45 minutes for water to run clear through the DPF
    My customer more than happy now seeing as his car has full power again
    Sep 2010
    in a box
    not saying it dont work depends whos car it is really as for you doing what i sed he wont be back with your idea he will in like 6month as it be blocked agen keeping you in work plus if you smash insides out you need it mapped off ecu
    PRESTON
    £300 on ebay for a replacement DPF if someone wanted to buy new. The cleaning of DPF's was covered last year on the forum, but thanks for the reminder for those who missed that post.
    It is a bone of contention, does one replace the DPF when clogged beyond cleaning and keep the emissions in check or have it and it's regen software removed? I imagine that debate would run into many pages, in fact i seem to recall it already has.
    It has to be said that DPF's block due to other issues, for example faulty EGR, fitting of a tuning box or when regens are not allowed to complete there cycle when owners switch off mid regen. My DPF is the original fitted to the car, the car has covered 108k and has never had an issue with the DPF, as it does its thing and cleans itself as it should.
    Sep 2010
    in a box
    depends how rich you are as i cant pay £300 every year say were as £200 say and remap my car and regen taken off ecu (mine was 250 BTW)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Got to better to put a pipe in its place when you map it out. The gases are not going to flow well when they hit the empty chamber. You might lose power rather than gain it back.
    Your car will be carrying less weight as well
    newport
    what does it do?
    Sep 2010
    in a box
    Quote Originally Posted by merikiito View Post
    good poing then you need to tape sensor and pipes out the way plus have you felt a dpf gutted?? there like 1lb not even that. and leaveing the old can there saves paying £60 for some pipe which is silly im getting mine all done with my new zorst as was cheaper that way or mite make my own not sure
    Sep 2010
    in a box
    Quote Originally Posted by taffy bhoy View Post
    what does it do?
    think of it as a cat mate
  1. Son has £1200 for a vec
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2012, 20:01
  2. F1 Qualifying 1200 ITV
    By Taffyopel in forum General Chat
    Last Post: 2nd August 2008, 15:00
  3. My Printer... hp 1200 ?anyone help
    By macdad in forum General Chat
    Last Post: 28th June 2008, 02:25
dpf cleaning garages dundee
vectra c dpf cleaning
dpf removing out dundee
dpf position opel astra
