Thread: Loud Grinding Noise When Braking?
    Regular Member JDX-SRI's Avatar
    Jan 2010
    Scotland
    Question Loud Grinding Noise When Braking?
    Hi Guys,
    I've recently noticed a loud grinding noise coming from the rear of the car when I brake.
    It started yesterday and is getting worse - and if I open the window when I'm driving slowly without braking I can hear a "screeching" noise from rear offside wheel.
    I took the rear offside wheel off and its really difficult to turn the disc with the handbrake off and no brake applied - and when it does turn there the noise is again.
    I had the 2 year service 2 weeks ago and they told me the brakes were in very good condition and didn't need anything doing.
    I checked again and the disc is fine and there is about 25% left on the pad.
    Any ideas?
    Regular Member se4's Avatar
    Aug 2010
    wales
    Snapped cable?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you checked both outside and inside pads? The insides are known to wear quicker
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Yep - check the inside pads. Bets the garage only looked at the outer pad.
    Top Gear Top Tip - buy the pad and disc kit. Pads alone are about £48, pads and disc kit is about £88, discs alone are about £160! Go figure!
    My rear brakes were grinding for ages before i changed them. Then it came back and sounded like the rear when the front were needing done.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like worn rear pads. Had exactly the same on mine, and they were down to about 1mm. One was on the bare metal! New pads and back to normal
    Jan 2010
    Scotland
    I didn't check the inner pad either!!
    Take it this isn't covered in warranty?
    Barrow In Furness, Cumbria
    Don't think brake pads will be covered under any warranty as it wear and tear / consumable parts.
    Jan 2010
    Scotland
    I had new pads fitted to both rear wheels on my last Vec for £90 including labour at a vauxhall dealer so hopefully will be around the same price now...
    When and how was the car purchased?
    It would be best to have the issue checked
    The OE warranty will cover discs and calipers
    The disadvantage with replacement discs is you may be asked to pay for the pads, but quite often they agree to include them
    Equally, if a caliper has failed they only pay for the one that failed, not both
    As above, if the inside pads have worn then that is quite normal
    The rear pads are really cheap, even on the 3.0 V6 CDTI they are only £25, but the dealerships charge at least 1 hours labour (about £60)
    Check the discs for grooves and excessive lip on the edge, replacements will add up to £60 (virtually no difference in labour costs)
    Jan 2010
    Scotland
    I bought the car from a Vauxhall Arnold Clark on 7th January 2010 - only had 10'000 miles on the clock.
    Had for 1 year 1 month now and now has 24'000 miles on the clock.
  1. LOUD grinding noise?
    By UncleMelon in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2012, 11:21
  2. grinding rubbing noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 09:49
  3. knocking / grinding noise
    By Graeme in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2011, 23:51
  4. brake grinding noise
    By li4m in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2010, 20:54
  5. Grinding Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 10th October 2006, 07:52
zafira dragging noise when braking
