Results 1 to 10 of 29
Thread: Can top mount bearing or arb bushes rattle?
    VIP-Member MCD's Avatar
    NE Manchester
    30 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Default Can top mount bearing or arb bushes rattle?
    Hi guys, well its doing my head in now, starting to ruin my enjoyment of a great car! I drove my old sri cdti today, which is also on 19s and eibachs, it's almost silent over bumps.
    I'm getting a muffled rattle, almost like the noise you'd get if bumper was loose, but its not! It's coming from upper suspension turret area...
    I'm thinking, could top mount bearing go rattly and noisey? Also I've done drop links, made no difference, while doing them I disconnected both and gave arb a good shake, it was solid so didn't do arbs... But thinking, even if inspected they are fine... Could they still rattle on road?
    What else rattles? Do shock absorbers go noisey? I cant think of anything else? Car drives fine, and suspension feels like it's working normally.
    Mines got IDS shocks, I've noticed with sport mode on the noise is slightly less... Perhaps as less suspension travel... Could this be a clue??
    Any ideas massively apprecciated guys...
    Mike
    Noobtune 220bhp / 270lb - (07) 2.0 turbo SRi XP1 NAV - SUNROOF/AFL/CD70/SRi Full leather/VXR exhaust/ VXR & XP2'd
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    i found this for you
    hope this is helpfull
    http://www.vectra-c.com/forum/showthread.php?t=101361
    NE Manchester
    30 Post(s)
    Engine : z20net
    Mileage : 80k
    So have any you guys had experience with noisey top mount bearings? What's the noise like?
    Cheers for any help?
    Mike
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    i just kept getting like a crunch noise when i went over speed humps
    mine was arb bushes noise has stopped now
    NE Manchester
    30 Post(s)
    Engine : z20net
    Mileage : 80k
    Quote Originally Posted by vectra ste View Post
    How do you mean crunch? Metal or plasticy noise?
    Cheers for your help mate
    Mike
    West
    I had a noisey strut top bearing on my preface just as mot was due & i was about to trade it in...
    It was a knock rather than a rattle when cornering over uneven ground, took the casing apart & packed the roller bearings with cv grease, saved me replacing it. hth
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    I have a knock from the rear off side, removed parcel shelf, spare wheel and made sure seats are locked into position and still a metallic knock, so had it up on ramps and had a look at my twin exhaust as well as any cables, also checked the arb bushes but all seams tight, readind posts it could be arb bushes so I will replace them but also the top control arm which I will remove, they look like they have the same type of rose bushes as a Vec b trailing arm has which if so I am very use to replacing as did it a couple of times in the past few years.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    Quote Originally Posted by MCD View Post
    Mike
    metal
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    Quote Originally Posted by skidmark1 View Post
    let us know how you get on
    keep us posted
    NE Manchester
    30 Post(s)
    Engine : z20net
    Mileage : 80k
    Was your suspension any noisier in general while it was at fault? I can't work out if it's a rattle, or loose noise... Defo got noisey suspension at the front at the min....
  1. Powerflex engine mount bushes
    By Caveman_nige in forum Handling & Braking
    Last Post: 6th May 2012, 15:16
  2. vectra top mount bearing question
    By borderman932 in forum Suspension, Wheels & Brakes
    Last Post: 27th April 2012, 22:45
  3. Rattle after anti roll bar bushes change
    By wayne10244 in forum Suspension, Wheels & Brakes
    Last Post: 24th April 2012, 19:13
  4. Radiator top mount bushes
    By philc1210 in forum Bodywork & Interior
    Last Post: 7th October 2011, 21:56
  5. Top mount bearing?
    By goafer in forum Suspension, Wheels & Brakes
    Last Post: 6th June 2010, 08:57
vectra c top mount bearing or bush
