Results 1 to 10 of 15
Thread: Heater gone belly up?
    Feb 2011
    cornwall
    Default Heater gone belly up?
    I have just bought a 2003 Vectra DTI 2L. there turns out to be a few (hopefully) little faults with it. but the main one is the heater / blower has stopped working? It was working on the top setting onlyto clear the windows, but then just stopped. Any ideas as to what it might be as i'm in the navy and trying to find time to get to the gaurage is hard and expensive! Cheers
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Resistor is most likely away. Easy fix for a resistor pack from the dealers or if your handy with a soldering iron its less than a quid for the part from maplins.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    you need one of these mate
    the same as dasarab said
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item3f074df6d9
    thats if you dont want to go down the maplins route
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    hope this helps you simpolej161
    http://www.vectra-c.com/forum/showth...t=21620&page=3
    try your fuse box first just before you buy a resistor pack.
    Feb 2011
    cornwall
    WOW that was quick. cheers for that!! will have a look at the fuses but it was working on number 4 only then stoped after making a funny noise.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 143000
    Quote Originally Posted by simpolej161 View Post
    what usually happens is water gets in through the pollen filter
    common fault on this forum
    have a look at this
    http://www.vectra-c.com/forum/showthread.php?t=128337
    Feb 2011
    cornwall
    cheers going to check my "scuttle" tray now! How easy is it to change the resistor, possibly the motor and the pollen filter? oh ye and where are they locaed and accessed? :S
    Feb 2011
    cornwall
    that could be why there is a damp sort of smell and the windows mist up terrible
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    How2 on how2 clean out blocked scuttle.
    http://www.vectra-c.com/forum/showth...=1#post1234916
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Resistor can be tricky. Once you locate it, it's simple. Pollen filter a doddle. If your motor only worked on Speed 4, your resister fuse will be shot. If it's now gone off altogether, I'd be looking at the main fuse for the blower. Not sure if it's in the end of dash or the boot, but I'm sure someone will confirm very soon. Don't replace the resistor until you've cleaned out the scuttle tray
  1. Heater
    By Daz d in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2012, 22:46
  2. Heater
    By sparky1292 in forum Bodywork & Interior
    Last Post: 21st April 2012, 19:39
  3. Heater
    By Vvgsi2004 in forum Bodywork & Interior
    Last Post: 8th February 2012, 18:05
  4. Belly pan for a veccy
    By oxenburger in forum Engine & Drivetrain
    Last Post: 20th October 2009, 13:18
  5. Heater Help PLEASE!!
    By jay146 in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2007, 18:06
