Results 1 to 10 of 24
Thread: Waterpump replacement
    Regular Member Maurice's Avatar
    Nutterden (D)
    Question Waterpump replacement
    Good evening,
    My 3.0 dti is in the shop right now getting a new waterpump. Unfortunally they have to strip down a large section of the engine..
    Could anyone tell me how long VX/Opel would take to make this repair??
    Just to check out my own garage...
    They also told me about an "helper waterpump".. Who know if it's there and what is it's function?
    Hope to hear from you guys,
    Kind regards
    Nov 2010
    *!dave!* - The Black Country
    Autodata state for a 2004 3.0 cdti
    3.60 hrs for pump remove and fit (total job)
    That is 3 hrs 36 minutes in proper english
    Nutterden (D)
    Quote Originally Posted by RS2000CUSTOM View Post
    Could you get this info by an original VX/Opel dealer too? Like a
    copy that I can show my garage
    Thanks for your fast reply!
    Maurice
    Nov 2010
    Quote Originally Posted by Maurice View Post
    Maurice
    What year is your car and spec and reg ?
    I will scan a quote and post it on here as a pic for you to print
    I will leave labour rate blank
    Nutterden (D)
    It's a Signum 3.0 CDTi V6 (Y30DT) from 07-2004 (Reg is german)
    If you could post it as a picture, that would be great!!
    Thanks, Maurice
    Nov 2010
    quality is a bit poor but you should be able to use it
    Nutterden (D)
    Thank you very much ,this will do the job!
    Will make a nice print at work tomorrow.
    2nd thanks , Maurice
    Full Member vectraturbocal's Avatar
    Aug 2010
    leeds
    i hate these autodata times these are set by doing the job on a new engine with all tools needed set out in reality its not like that, im a mechanic and everyjob is different even if its the same job (if u get me lol) you get rusted bolts, things siezed etc etc, i wouldnt listen to these times obviously unles they try charge 3 times the hours or over the top but sometimes a 1hour job can take 30mins other times it will take 1hour and half.
    Nov 2010
    Quote Originally Posted by vectraturbocal View Post
    Like most publications Autodata is to be used as a guide
    Without it I could under quote a job as much a over quote and then loose the job whilst with it I am giving myself a fighting chance to be competitive when quoting a customer for the repair required
    As for tools required for the job surely having the correct tools only make the job a whole lot easier so therefore the job becomes more efficient
    Aug 2010
    leeds
    didnt say correct tools, do you know how they get there times for technical data? theres a garage (showing how smart i am i cant remeber the name lol) and they get the brand new engine and every tool they need is laid out on a table in order then they time it, its good as a guide but sometimes its way off and then you get people coming up saying auto data say this auto data says that its a joke at times
  1. 1.8 Waterpump
    By Tinks in forum Engine & Drivetrain
    Last Post: 10th January 2013, 23:29
  2. cambelt kit and waterpump
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 19th June 2012, 20:30
  3. Waterpump
    By Tam80 in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 20:14
  4. waterpump failure?
    By toast in forum Engine & Drivetrain
    Last Post: 28th October 2010, 23:52
  5. waterpump
    By barry0101 in forum Engine & Drivetrain
    Last Post: 21st January 2010, 09:42
