Thread: Where is a barometric sensor 2.2dti?
    Oct 2010
    uk
    Engine : 2.0t
    Mileage : 117000
    Default Where is a barometric sensor 2.2dti?
    today opcom found:
    P1105 - Barometric Pressure Sensor Circuit Low Input
    (03) - Present.
    where is that sensor? any links with photos how it looks, or maybe it comes together with MAP sensor?
    Also i changed both front bearings with newer abs wire plugs, so i just resoldered it but now shows abs error. is there diffrent abs sensor on newer models? Both without IDS.
    Regular Member VectraElite 2.2DTi's Avatar
    Sep 2010
    Longfield
    when i Wikipedia'd the word "Barometric" this came up:
    A barometer is a scientific instrument used in meteorology to measure atmospheric pressure. It can measure the pressure exerted by the atmosphere by using water, air, or mercury. Pressure tendency can forecast short term changes in the weather. Numerous measurements of air pressure are used within surface weather analysis to help find surface troughs, high pressure systems, and frontal boundaries.
    Regular Member nauric's Avatar
    Sep 2009
    LATVIA
    Quote Originally Posted by riauba View Post
    today opcom found:
    (03) - Present.
    Left top corner near MAF, its like boost sensor
    Oct 2010
    uk
    Engine : 2.0t
    Mileage : 117000
    Quote Originally Posted by nauric View Post
    sposibo bratan iz latvij
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    today opcom found:
    (03) - Present.
    The Barometric Pressure Sensor measures the air pressure around the outside of the vehicle, a normal reading on a dry and bright day would be around 1008 mbs. This can vary considerable depending on the weather outside i.e high pressures dry, bright, sunny, and warm, and low pressure being very stormy weather. The BPS and the boost pressure sensor work side by side and calibrate and meter the charge pressure from the turbo charger, keeping a constant pressure without "over and under" charging the air intake system
    Oct 2010
    uk
    Engine : 2.0t
    Mileage : 117000
    it costs £40 new and found just a one used on ebay for £35.
    Sep 2009
    LATVIA
    Why you say thanks in poor russian??
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. Barometric Pressure Sensor - P0105
    By Chris B in forum Engine & Drivetrain
    Last Post: 5th June 2012, 18:50
  3. p1105 Barometric Pressure Sensor problem
    By stuarty1 in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2012, 08:34
  4. barometric peasure sensor any1 know were it is??
    By barrymanalow87 in forum Diesel Engine related
    Last Post: 13th March 2010, 00:15
vauxhall vectra 2.2 dti barometric sensor
vectra barosensor
barometric sensor for 2.2 engine
vectra c 2.2 dti boost pressure sensor located
opel 2.2 dti barometric pressure
opel vectra c 2.2dti sensor atmosfere pressure
vectra c barometric pressure sensor
vauxhall vectra barometric sensor
2.2 dti baro sensor location
barometar sensor vektra b 2.0 dti
opel zafira 2.2 dti barometric pressure sensor
opel vectra barometric pressure sensor
vauxhall 2.2dti ambient pressure sensor
opel vectra b 2.0 baro sensor
barometric pressure sensor circuit low input p1105
atmospheric sensor vectra c
vauxhall vectra barometer sensor
code p1105 vectra 2.2 dti
where is the boost pressure sensor on a vectra c 2.2dti
where is boost pressure sensor on 2.2 vectra
p1105 barometric pressure sensor on vectra diesel
vectra b sensor barometer
