Results 1 to 3 of 3
Thread: How to test the vacuum pump?
    jilava
    Default How to test the vacuum pump?
    Does anyone know how to test the vacuum pump on a cdti 150? What vacuum level should it produce?
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    disconnect it and stick your thumb over the end and see if you can remove it If it draws blood its sucking good, if it doesnt then you may need a new..
    and finally a seriours answer... you can buy a 'vacuum' gauge which will tell you the vacuum its creating in 'Hg'. You then check this against what it should be and draw your conclusion
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    jilava
    Thanks plasma, what do you think the vacuum should be?
  1. Vacuum pump reliability
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 19th April 2012, 20:42
  2. vacuum pipes from pump
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2011, 22:00
  3. vacuum pump leak... :(
    By geleziux in forum Vectra C / Signum Troubleshooting
    Last Post: 25th May 2011, 21:22
  4. vacuum pump
    By Dougb in forum Engine & Drivetrain
    Last Post: 30th June 2010, 22:41
  5. EML - Vacuum Pump ?
    By matiny2k in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2008, 20:53
