Thread: 2.2 dti Turbo problem
    West Yorkshire
    Default 2.2 dti Turbo problem
    Hi Guys, hopefully somebody can point me in the right place, My turbo started whistling really loud under load, and now just recently its whistling even on tick over? I have check the obvious pipes seem ok, got somebody to rev it so i could listen, and the noise is coming from the turbo.
    Could it be a gaskett or more likely the turbo.
    Sorry its Vec C 2.2 dti. its had a turbo on just over a year ago so out of warranty now.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Strange with it being a new turbo. Is there any play in the shaft? Take the rubber pipe off that goes into the turbo and you should see the blades on the compressor. WITH THE ENGINE OFF (don't want fingers to be lost!) give the shaft a gentle wiggle and see if there's any play in it. Side to side and front to back.
    Regular Member Innes's Avatar
    Plymouth
    Did you take the plastic cover off first? I tired pin pointing the whistle and it sounded like it was coming from the turbo but when I took the cover off it turned out to be a split intercooler hose at the front. The cover was redirecting the air and sound towards the turbo! Remember to give the inter cooler hoses a squeeze to open up and cracks in them otherwise they are hard to spot. They tend to go on or near the corners.
    You probably know where everything is but thought i'd post this pic up to help :-)
    West Yorkshire
    Thanks, for that will have a proper look at weekend, Did you find it was using more diesel because of the split hose as well?
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by Shortland78 View Post
    If your MPG has dropped then it sounds like a split in the intercooler pipe. Are you producing more black smoke than the norm?
    Plymouth
    My MPG had been crap anyway but I think it was down to needing a good service as the MPG was still poo after I had replaced the hose. Now had it serviced which included and engine flush and now getting 42mpg instead of 31mpg!!
    I only noticed the split when it sounded like an angry snake under the hood when I put my foot down. I didn't notice any black smoke (and its always run clean - no smoke at all) but when my home made hose popped off recently it smoked heavily. Upgraded my weak jubilee clip with a T-Bolt Clip and it hasn't popped off since.
    West Yorkshire
    Thanks for the advice, will change the hose and give her a service, will keep you posted if it cures her or not
  1. 2.0 Turbo problem
    By the stig in forum Engine & Drivetrain
    Last Post: 4th March 2010, 20:31
  2. Turbo Problem
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2009, 21:01
  3. problem with turbo or ?
    By chikenbud in forum Engine & Drivetrain
    Last Post: 1st February 2009, 16:03
  4. Turbo Problem...
    By dankidd in forum Engine & Drivetrain
    Last Post: 11th August 2008, 22:55
  5. 2.0 DTI turbo problem
    By Vibez_Uk in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2008, 21:15
vectra dti turbo.fault
vectra dti turbo problem
vauxhall vectra 2.2 dti turbo problems
