Thread: Rear brake Caliper
    Feb 2011
    Fife
    Default Rear brake Caliper
    Hi people new here, A friend is looking for me to change his rear brakes on his vectra C 2.2 sri.
    He also needs his off side caliper replaced as its seized. Is there any special tools or precautions to be taken when doing the caliper. any special bleeding procedures?
    Any info is greatly appreciated.
    Stuart
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    A piston windback tool will be a great help as the rear pistons wind back not just push back as on the front calipers. A long torque bar will also help as the caliper retaining bolts are a "bit" tight. VX say replace the caliper bolts but I just use a drop of "loctight" and replace the old ones, they are so tight that they will not drop out. Other than that use all the normal proccedures when dealing with brakes, be clean etc.
    Wales, UK
    The windback calliper adapter is an odd size on the Vectra. The common ones that are stocked on the shelf in most places do not fit. Some order the correct one online, however I filed the pins down on the one I got from Halfords, worked fine. Maybe an option if waiting for delivery is a problem.
    Jul 2006
    TENTERDEN KENT
    I think the pin centres are 21mm, I also had to grind my ones down to fit.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by carpet View Post
    You dont have to move that to take the calliper off mate, just undo both slider bolts, the caliper bracket stays in situe. You only have to remove that if you change discs.
    If your fitting a new or good used caliper then a set of long nose pliers will be fine as you'll be winding it back on the bench and by its nature of being new/newer if will be less tight. Wind it all the way back is so less bleeding is needed when fitting.
    Once its fitted pump the handbrake lever (on the caliper) to push the pads back up, then again pump the actual handbrake several times.
    Its then just a case of bleeding that part of the circuit.
    I did mine the other week with a used item from ebay. Its a very easy and quick job to do.
    You'll need a 7mm allen drive to take the slider bolts out and a rewind tool or pin noes pliers to wind the piston back in.
    Other than that you only need some mole grips to pull out the outer handbrake cable from the caliper casting.
    HTH
    Steve
    PS, not forgetting the spanner for the bleed nipple, sorry off the top of my head I cant remember the size.
    Feb 2011
    Fife
    Thanks for all that guys, some good info there. will double check the pin centres on the new caliper and make a wind back tool at work.
    I was just unsure of the bleeding procedure as i had read on the internet not to bleed using conventional methods but a pressure bleeder to protect the ABS.
    He had been quoted £220 for the caliper at a garage and dingbro quoted me £75 +VAT so hes making a saving.
    Got all the mentioned tools so hopefully everthing should be ok.
    Vehicle : SRi
    Mileage : 137000
    I used a pressure bleeding kit, but you might need to put some electrical or plumbers tape round the thread of the reservoir as the one that came with my kit was just a tiny bit too big, but the tape did the trick.
  1. Rear brake caliper problem
    By siadwel in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2012, 16:37
  2. Rear brake caliper
    By NI-2.2SRI in forum Handling & Braking
    Last Post: 16th March 2009, 19:33
  3. rear brake caliper
    By jerc in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2007, 13:56
how to rewind brake calliper on vetra 2.2
vectra c rear brake wind back procedure
vauxhall rear caliper piston trouble winding back site:www.vectra-c.com
vauxhall vectra c rear brake caliper piston
