Thread: 2.2 dti turbo boost gauge
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    Talking 2.2 dti turbo boost gauge
    toying with the idea of fitting a boost gauge had a look to see what i can find out, wich gauge ect. 30 psi is that right? also that ill have to tap into the big black rubber pipe on the right hand side going into the throttle body is this the only place as id probably have to replace the whole pipe and put a metal piece with a nipple in somehow ??
    Jul 2010
    doncaster
    would a 4 inch long alloy 2" pipe go in the existing pipe if i cut it?
    Jul 2010
    doncaster
    any one?
    thanks.
    stockport
    Arrow
    Quote Originally Posted by dansri View Post
    I can see where you are going with this one.It does seem to be the better alternative for obvious reasons,however,you might just get a more accurate reading,as the metal pipe section where you are taking it from,wouldn't be under any type of distortion from pressure.....yes??????.FELIXX.
    Jul 2010
    doncaster
    i would think so, i was more worried if i just put a nipple in the standard rubber tube it would poss split?? i was wondering if i could tap into the plastic pipe just below the rubber one??
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    http://www.vectra-c.com/forum/showthread.php?t=108654
    Have a look here I tapped into the plastic pipe
    Jul 2010
    doncaster
    thanks for that, thats where i will do it. everything else i have found before was suggesting tap into the rubber pipe. that is just at the bottom of the pipe that leads to the throttle boby insnt it? mines a 2.2 dti.
    kings lynn, norfolk
    Yup the plastic pipe come from intercooler to the rubber pipe you which goes ti throttle body
  1. Turbo boost gauge
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2013, 09:33
  2. Turbo Boost Gauge on z20net
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2010, 22:56
  3. Turbo boost gauge
    By dannysport18 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2008, 16:48
  4. turbo boost gauge
    By jay-z in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2007, 15:38
  5. boost gauge.......
    By Houstie in forum Diesel Engine related
    Last Post: 16th October 2006, 02:25
which intercooler pipe do you tap into for a boost gauge on a vectra c dti
2.2 sri vectra dti boost pressure
boost opel dti
signum 2.2 dti turbo boost
vectra 2.2 dti boost gauge
turbo boost 2.2dti
2.2 dti turbo pressure
signum turbo boost gauge
install boost gauge vectra dti
can you fit a supercharger on a vectra 2.2 diesel
vauxhall dti boost gauge
how fit a boost gauge on a vectra diesel
where does turbo boost gauge pipe go to on a vauxhall 2.2dti
turbo boost opel dti
turbo boost gauge fitting vauxhall 2.2 dti
wiring boost gauge ecotec 2.2 dti
fitting boost gauge to 2.2 dti
