Thread: Springs
    Feb 2011
    Grimsby north east lincs
    Default Springs
    I know this may have been asked before, but do vec c springs fit the signum as well ? If anyone could tell me id be gratefull.
    Thanks.
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The fronts are the same across the range and the signum and estate rears are the same as I recall All of this is subject to weight ranges which vary depending on engine and gearbox fit.
    Feb 2011
    Quote Originally Posted by paulhb View Post
    Ok thanks for the info mines going to be a 2007 2.8v6 turbo and a mate of mine has offered me some springs and shocks off a vec c sri which i was hpoing would fit mine.
    23 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Check the weights on the B piller info plate and compare but if his is a hatch the rears wont be any good for yours different weight and spring rates. Your front weight is likely 1100kgs and if they might be ok if his is a diesel.
    Feb 2011
    No his is a 1.8 sri its an uprated lowering kit he's selling.
    23 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    His front axle weight will be lower which might make yours sit even lower than his but its the rears that will be the issue mate sorry
    Feb 2011
    Ok i may try them and see what it sits like, we shall see.
    Regular Member Mr Hyde's Avatar
    Feb 2011
    Suffolk
    Just remember it's not just what it sits like, the compressionand rebound properties won't be right if the weights are out...
    WGAF#5
    the 1.8 shocks will be completely inadequate for the job in question ... so much so that the front will be insufficiently supported and may end up rupturing the shocks
    and costing you lots of money
    have a Word with Howard (porkballs29) and see which set he purchased (2.8 design manual)
    if you look at Soulmans latest car he fitted springs especially designed for a VXR and you can see the difference and how much lower the rear now sits as there designed for a hatch and not a signum (2.8 elite auto)
    regards
    Dez
    Feb 2011
    Cheers Guys.
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
