Results 1 to 10 of 11
Thread: yellow Oil can light on dash
    Oct 2009
    norfolk
    Default yellow Oil can light on dash
    Hi guys,
    can you help me,
    when starting the car and turning off, i get an yellow oil can with a spanner through it on the rev counter, goes off after a minute, checked the oil and it was low, put 1.5 ltrs of oil in and i cant read the dip stick very well as oil isall up the steam, Im worried about over filling! yet the light is still on?
    Looked around the engine and cannot see any obvious oil leaks , non under the car or in the engine bay. Can a 1.9 cdti burn this much oil? car does about 20miles a day, mostly A roads 50-60 (not thrashed very much)
    thanks
    Gareth
    Mileage : 000
    Sounds like you need to top up the engine oil. Check the dip stick level as soon as possible.
    Oct 2009
    norfolk
    Ps I have a fault code reader, so plugged it in and no fault codes were recorded, any suggestions?
    Oct 2009
    norfolk
    Hi Ed,
    have taken the dip stick in and out several times i think i put oil all up the stem so it smears when the dip stick is removed, so i will go out and check it again in a minute or two.
    where would all the oil go?
    It could be a faulty switch. most fault code readers will only read a few faults, not all of the massive range of possibilities!
    Regular Member sebadee's Avatar
    macclesfield
    When was your last service as fro
    What I've read on this forum the oil/spanner light comes on before and after engine switch off/on when below 1000 miles to next service and will stay on constanly when below 100 miles
    You can check by pressing and holding odometer reset button
    Regular Member Innes's Avatar
    Plymouth
    Did it have 1000 under the icon? If so it means you are due a service in 1000 miles.
    Plymouth
    I hope you haven't over filled your oil now!
    Oct 2009
    norfolk
    Thumbs up
    Quote Originally Posted by Innes View Post
    Hi Innis
    Im not sure, the symbol is right but the full size with no text underneath, having said that when I hold the pin in i get 105 come up on the odometer
    - I brough the car two years ago, fourth hand and the servicing history has long gone I have done two oil and filters changes myself. first week of Dec just a habit and its easy to remember ( hence only recently changed the oil) I had no idea the car had a service interval. Is it possible to reset the service interval or set it for the next one?
    On the subject of oil, guilty - over filled it alot! drained it all out tonight and put the right amount back in!
    Oct 2009
    norfolk
    Hi guys thank you for your help - I think i was seeing hte oil service light
    had a surf on the forum and found this thread on how to reset the service interval,
    http://www.vectra-c.com/forum/showthread.php?t=30344
    Ive posted it here so that anyone else with a similar problem could give it a go also!
    now got 15K miles to go until it hopefully comes back - just enough time to forget what it is again!
    thanks guys!
  1. Yellow oil can on dash. 1.9 cdti 150 Vectra
    By Hover80 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th September 2010, 21:15
  2. yellow Symbol? on dash
    By dodydigital in forum Engine & Drivetrain
    Last Post: 25th April 2009, 16:06
  3. yellow Engine light perm on dash !!
    By Ghosty621 in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2006, 04:20
vecrmtra c yelkow oik
reset service light 04 vectra
vauxhall vectra oil can light
vectra warning symbols yellow oil can
vectra c oil can light
opel vectra c oil service
vectra c oil symbol and 1000
vectra c service sign
vauxhall vectra c service light look like
opel service interval symbol
oil vectra icon
opel vectra c prietaisu skydelio simboliai
vauxhall vectra oil light
signum amber oil can light clutch
vectra c yellow oil control
opek yellow oil light
image of service light on vectra c
opel vectra c oil change intervall
service light vectra c
reset service vectra c
opel signum oil service light
Vectra C service icon
Oil Service Reset Vauxhall Vectra 2003 -site:engine-codes.com -site:obd-codes.com
what does the oil and spanner light mean on a vauxhall vectra
how to reset service warning on signum
