Results 1 to 10 of 16
Thread: Vectra c 3ltr v6 fault code
    Regular Member crayon's Avatar
    Swansea
    Default Vectra c 3ltr v6 fault code
    Hi guys had a spanner come up on the dash had a friend plug his coder in and it came up with
    p0105 map/baro circuit malfunction
    Does anyone know what this means lol
    Full Member Big Sig's Avatar
    Mine did that, clean the boost sensor It cured mine
    Swansea
    Ok thanks i will give that a try
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    Swansea
    Quote Originally Posted by vectra ste View Post
    still no clearer to the problem lol
    Regular Member david.aka.judas's Avatar
    Suffolk
    Its the boost sensor that measures the pressure in the manifold. I bet its blocked solid.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Are you sure? There's another sensor thing in the manifold...perhaps that measures intake temperature
    Swansea
    Right thanks for the help guys, i found the boost senser funny really cause its got boost senser writen on it lol.
    It was all blocked up so i have cleaned it all out refitted it.
    Now a spanner has gone from the dash but now the engine management light is now on and the car is in limp mode............
    Any help??????????
    Quote Originally Posted by Celes View Post
    Yes I'm sure a boost sensor measures pressure and a temperature sensor measures temperature. Simples.
    OP. How did you clean it? Is it seated correctly and everything plugged in correctly?
  1. Vectra C (Z18XE) fault code
    By Alexander79 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2012, 19:46
  2. Vectra SRi C alarm keeps going off code error fault
    By Tapie in forum Vectra C / Signum Troubleshooting
    Last Post: 8th September 2011, 20:53
  3. 2003 Vectra fault code??
    By mossy2432 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th January 2011, 18:52
  4. vectra c fault code
    By cavie in forum Engine & Drivetrain
    Last Post: 7th December 2010, 17:54
  5. Fault code on Vectra
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 14:41
