Thread: 2004 vectra 3.0cdti oil
    Feb 2011
    lisburn
    Default 2004 vectra 3.0cdti oil
    Hi all,my 3.0cdti elite is due the 100k service any thoughts on grade of oil,should you use something slightly thicker than 5/30 considering milage or continue with the 5/30 fully syn?
    Bristol
    Vehicle : CDTI 150
    5W30 is whats recommended by Vx. However a 5W40 that meets the GM-LL-025B standard or the Dexos 2 is ok.
    This will stay thicker at high temp, reduce noise and will very slightly reduce fuel comsumption.
    Full Member Big Sig's Avatar
    Renualt use 5w30 with the same engine in their cars so its ok to use.
    If its not burning any or losing any i'd stick with 5w30 though.
    If you continue to use GM-LL oil, then you can continue to use the Eco Flex or long service intervals (20K or 30K miles)
    If you swap to 10W40 or semi-synthetic oil then you can reduce the oil and filter changes to 10K miles
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mine used 0.5L of oil in 10k, 3k where done in Germany at very high speeds so can't complain. The 5w30 is still good for my engine at 130k+
    Jun 2011
    Elland
    The GM oil is to spec and should be cheap. There is an alternative brand that does not have low life: http://www.millersoils-online.co.uk/...ENGINE_OIL.htm
  1. 2004 3.0cdti signum auto
    By scou5er in forum Y & Z30DT Specific
    Last Post: 19th January 2013, 18:19
  2. For Sale - Vectra 3.0CDTi SRI
    By spatch in forum Cars for sale
    Last Post: 9th October 2010, 11:45
  3. Vectra 3.0CDTi Auto
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2009, 21:57
