Results 1 to 10 of 11
Thread: 12v power supply from boot?
    Regular Member Craig1985's Avatar
    harwich essex
    Default 12v power supply from boot?
    I'm after a 12v power supply front he boot area, anyone know of any ?
    Regular Member Jezzy's Avatar
    S.E
    Open the panel on the left hand side of the boot, and find the empty fuse slot next to the 40A fuse - that's an "always live" 12v supply. Just wire it up and get a 12v power socket from Maplins.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Theres a how2 for this somewhere.
    S.E
    harwich essex
    My wiring for my towbar equires a 12v power supply( for the relay bypass thing) will using a perm live give me a flat battery if left long enough?
    S.E
    Permanent live simply means you can still use whatever you've plugged into it even if the ignition is off - whether that will drain your battery depends entirely on what you connect it to and how much power its using - will your towbar be using power all the time? I suspect not....
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Would you prefer an ignition live?
    harwich essex
    Ignition live would be better I think. Not sure if the relay bypass box would draw power even if there was no trailer connected?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    You can use F17 mate. Get one of THESE then you can fuse the original circuit and also protect the take off independently.
    harwich essex
    Never seen one of those before. Cheers that should do the trick.
  1. help with power supply
    By vxr_and in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2012, 12:21
  2. Permanent supply in boot?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2010, 15:06
  3. 12 v supply in boot of signum
    By IBarfoot in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2007, 18:04
  4. Power Supply for GPS ??
    By AirCooledHeaven in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2006, 21:09
  5. Power supply
    By Robin in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2006, 13:06
vectra c 12v ignition in the boot
opel vectra c 1.6 live power in boot
vectra c 12v boot
vauxhall insignia boot permanent 12v power
vectra c 12 volts ignition in the boot
