Results 1 to 10 of 29
Thread: Spanner Light
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Spanner Light
    Got into the car this morning, started the car and drove off, I then noticed after about 100 yds that the spanner light was still on.
    I pulled over switched the engine off and then re started and the light had gone off, the car drove fine for the 8 mile journey I did.
    After a few hours parked I returned to the car, proceeded to start the car, I noticed when then engine was started the spanner light was still on. I swithched of and re started and again the light had gone out.
    There appears no be no problems whilst driving.
    Also, now that the light was on after starting would this store the problem if there is one?
    The Car's a CDTI 150
    Any ideas
    Thanks.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    up
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    Other similar threads mention glowplugs needing changing
    West
    in the morning see if it does it again, this time do not turn off the engine... se how long it takes to go out.
    if it's the a glow plug out the spanner will usually go out after about 5 mins of driving (once the engine has warmed a little)
    I have just replaced all mine today - after having these symptoms - with no fault codes stored.
    hth
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    What sort of cost an I looking at to get these plugs changed?
    Leeds
    Quote Originally Posted by Sebastian B View Post
    Mine cost £97 with the garage supplying the plugs, could have got the plugs a little bit cheaper from elsewhere and the labour charge was for half and hour.
    West
    the plugs themselves are £10 each & it's also a simple diy job if you follow the how to
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    My local dealer just quoted me £139.20p
    Jul 2010
    Skipton
    hth
    Did this remove the spanner light?
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    This morning I switched the ignition on then off and then back on again.
    I theory the glow plugs warmed up on two occassions, when I started the engine the spanner light when straight out as normal.
    I will keep you posted on my findings.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
