Results 1 to 10 of 17
Thread: She won't start! 2.2 DTi
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default She won't start! 2.2 DTi
    Right.
    Thinking leakoff pipes. Sounds like no fuel getting in, got half a tank in at the moment. Tried carb cleaner into intake but still no go. Any other ideas on getting her going? Im not at home.
    Sorry this is brief - on an iphone.
    Cheers.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Can you get a tow off someone? 2nd gear clutch up, will get the fuel through within 100' of road.
    Si
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Try to give it a push down the road as si_hoss said
    If you're not sure it's getting fuel try this http://www.vectra-c.com/forum/showthread.php?t=107779
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Celes View Post
    That's a good guide I found this morning which next time mine doesn't start for whatever reason I'll be trying.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Didn't think of a push start. Cracked the injector pipes off and tried cranking over but never got any diesel to the injectors. Going to try a new fuel filter tomorrow. It's parked up at my dads mates garage.
    No thought of trying to push start it!
    Cheers everyone.
    West
    have a good look at the fuel filter housing for cracks while you at it
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I will do, cheers.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Are you 100% sure you don't get fuel to the injectors? Tried a cheap code reader if you're getting any fuel pump ECU faults?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    We cranked it in total for a good 30 seconds and not so much as a dribble, no. If its still the same tomorrow, I'll go and have a look at it tomorrow with OP-COM.
    Cardiff
    Alright mate,
    I recently had this problem, I chaned the Glow plugs, Fuel filter, leak off pipes, then finally injector seals which solved the problem.
    You might want to get a battery booster or Jumps so you dont drain the battery either when your cranking it so many times which i did!
    also dont know if this is true but parking it on a slope facing down.
    Hope this helps
  1. car won't start :-(
    By michael_linford in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2012, 19:31
  2. Were do i start
    By MCCABE in forum Engine & Drivetrain
    Last Post: 6th March 2011, 21:34
  3. 2.2 sri non start
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 13th February 2011, 00:44
  4. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  5. 2.2 DTI will not start!!!!
    By Mark121 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th September 2010, 13:02
