Thread: need some help
    Feb 2011
    newton abbot/devon
    Default need some help
    First off hi all as iv just joined
    I have just got my first vectra c 1.8 16v but it has a few problems, first thing is that the heater dose not work on any speed
    And second both front windows do not work and everything on that switch donít work
    Jul 2009
    The Rift, Cardiff
    Search 'maplins heater resistor' for a possible fix for less than £1 for the blowers.
    As for the switch, pop it out of the door and check the wires are plugged in properly, it is also worth making sure the connector between the door and body is not slightly loose (but that would usually cause locking problems).
    Sep 2009
    Audley STAFFS
    I take it you have checked the fuses?
    Full Member Big Sig's Avatar
    Or a new switch panel?
