Results 1 to 2 of 2
Thread: Juddering / Blue Smoke
    Midlands
    Default Juddering / Blue Smoke
    Hi,
    The car had 2 glow plugs failed which have been replaced, I still get this juddering on idle and at low rev's, I've not lost any power as the performance is still there, whilst it's juddering I do notice blue smoke from the exhaust and also discovered blue smoke upon heavy acceleration....I've had the injectors tested by my local garage by a leak off test, all four filled the pots up about the same....I'm still suspecting that this is likely a injector problem as the juddering feels like a misfire....if anybody can shed some light on this issue I'd be very grateful.....Thanks
    Suky
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Blue smoke means the engine is running on oil and as there is juddering inolved sounds like the turbo is a possibility, allthough turbo's don't always cause a reduction in power (in operating range) when goin faulty. I have assumed however you have had the usual culprits ruled out - cylinder head/valve stems etc.
    Whatever the fault get it sorted asap as deisels can run on their own oil meaning you can't switch them off.
    Gazza4
  1. Replies: 0
    Last Post: 3rd February 2013, 13:54
  2. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  3. blue smoke
    By Swedge in forum Engine & Drivetrain
    Last Post: 28th October 2012, 13:09
  4. blue smoke
    By matt.d in forum Engine & Drivetrain
    Last Post: 26th June 2011, 11:34
  5. 2.2 blue smoke
    By pyper_honda in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 22:52
vauxhall vivaro blue smoke and juddering
