Results 1 to 10 of 22
Thread: Alternator
    Default Alternator
    Drove into work this morning and the alternator light cam on, then the ABS light came on, then the power steering went and finally the engine management light came on.
    Was it just coincidence that all theother lights came on as the power was going. Also it was sounding a bit rough.
    Please help.
    Regards
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    get it looked at mate or you will be walking home sounds like your alternator or belt has gone
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Definitely the Alternator
    As the power from the battery drains away, everything shuts down, ie, ABS, powersteering, etc...
    stockport
    Exclamation
    Sounds like the auxiliary belt is on it's way out,if not already kaput!!. FELIXX.
    Thanks, dropped it off at the garage, is it a big job and expensive?
    Glasgow
    As you said mate its the alternator, as the battery drains its like a domino effect.
    Will it just correct itself when a new one is put in?
    Glasgow
    Yeah it will be fine with a new alternator.
    Regular Member johnny1983's Avatar
    Ryton, Gateshead
    I just had the same problem at the end of last month, cost 220 for a new alternator and labour. will sort the problem out for you.
    Was your power steering heavy? It is unbelievable how heavy it is to drive
    It was like driving a tank, great fun getting into Manchester
  1. New Alternator
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2012, 00:50
  2. which alternator
    By john1 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2011, 13:32
  3. Alternator
    By m8wos in forum Engine & Drivetrain
    Last Post: 10th December 2011, 20:54
  4. what alternator do i need?
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2011, 14:50
  5. alternator
    By hitcho in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 21:01
