Thread: Corsa VXR wheels
    Norwich
    Trim : SXi
    Engine : 2.2
    Default Corsa VXR wheels
    Will corsa VXR wheels fit the veccy? I know the PCD is 110 and they are 5 stud but is the bore 65.1 as on the veccy?
    scottish region
    yes they should fit
    Feb 2011
    essex
    What you mean is,is the offset(ET) the same as on the veccy c.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The pcd and centre bore are correct, the offset is too high though and you need to use 5mm spacers iirc
    Norwich
    Trim : SXi
    Engine : 2.2
    So basically without the spacer the wheels will sit inside the wheels arches further then veccy wheels?
    Cheers for the replies
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by the_wave_rider View Post
    Yep and may foul on the suspension strut or brake caliper
    Full Member Big Sig's Avatar
    They will fit as I looked into them myself.
    Norwich
    Trim : SXi
    Engine : 2.2
    Ok cheers may get a set I like the snowflake design but want something different. Think i have found a cheap set that I can refurb and spray graphite grey and I already have some 10mm spacers
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    with a spacer you can make any wheel fit can't you?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    What offset are they? I thought there was someone on here with them fitted and he had to use spacers
    Quote Originally Posted by Caveman_nige View Post
    Half shaft FAIL
  1. corsa vxr wheels
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2009, 11:47
  2. Corsa VXR wheels
    By julian924s in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2009, 23:01
  3. corsa vxr wheels
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 22:59
