Thread: Suspension Parts
    Regular Member themarbleman's Avatar
    sussex
    Default Suspension Parts
    Going to be changing springs and shocks soon,Probably Bilstein B4 and either Eibach or Pi springs.Might go down the route of Supersport Sprint Kit.
    The real question is are there any other parts required ? Top mount ? I think its called but not sure,if im going to be replacing springs and shocks i want to do the job properly,can i purchase additional items and just bolt on a complete new shock assembly ?
    Any help would be appreciated.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I am doing the same. Top strut bearing will probs need doing on both sides at the front. I went for the whole lot, but front drop links are cheap enough off ebay and an easy swap.
    ARB bushes are a pain so unless they are knocking its not worth buying in. I did the rear upper control arms also and will be doing my rear drop links too
    If it ain't broke don't fix it... or you will have loads of pointless work and expense outstanding like me lol
    sussex
    Thanks for that..Are there any bushes at the bottom of the spring ?
    Bordon, Hampshire
    Nope, as far as I know the bottom of the spring just mounts into the shock which will have a little groove for the end of the spring to seat into I havent taken anything apart on mine at the mo as still waiting on the springs but thats the general layout
    Regular Member mann3210's Avatar
    scotland, perth
    better getting your car wheel aligned to prevent uneven tyre wear
    sussex
    Thanks to all above for the info...
  1. Suspension parts...How many ?
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 29th August 2011, 12:23
  2. Suspension parts ordered
    By Graeme in forum Handling & Braking
    Last Post: 31st March 2011, 18:59
  3. Suspension Parts
    By John LE in forum Part Numbers
    Last Post: 15th March 2010, 01:58
