Thread: Vacuum reservoir problem
    Feb 2011
    Aberystwyth
    Default Vacuum reservoir problem
    Have been changing the intake manifold on my vectra 1.9 cdti and when taking the vacuum hoses off the vacuum reservoir one of the small pipes broke off, there is another blanked pipe next to it, what would happen if I blank the broken one off and connect to the other one, (garage say they can only get one from germany and it will take 17 days)
    Any Ideas?
    PRESTON
    i believe it would work just fine. The later cars didn't have the vac reservoir and the pipe ran direct from the vac pump to the boost control valve on the front panel.
    Reading
    Works fine without it, I broke one of the pipe fittigs off my tank, went to VX to get another one, and was told to just bin it, as the later cars don't have them anyway, used a length of silicon hose to go bypass the tank, and have had no problems since. (until the cambelt split and caused the timing to jump)
    jilava
    Hi, anyone care to put up some pics of this vacuum tank bypass mod?
    PRESTON
    it's easy, just take a vac pipe direct from the vacuum pump on the top right of the engine, the thin pipe, to the boost valve on the slam panel and secure it from flopping round with cable ties. Then leave the reservoir and pipes in place on the engine, no need to remove those.
    jilava
    Thanks Barney, and the pipe that leads to the tank remains with no hose on the vacuum pump side. Should this be sealed off ?
    PRESTON
    no need to seal either end of the metal pipes leading to the vac reservoir, as it is no longer in use.
    Feb 2011
    Aberystwyth
    My car is fine now blanked off broken nipple with a screw and some silicone and conected to the next nipple that was blanked off, would take 18days from vx as they have to get them in from germany and all the ones in the brakers yard had the same problem.
  1. Brake Fluid Reservoir Cap
    By jonnyaykroyd in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2011, 20:46
  2. Vectra b vacuum problem
    By diddy boy in forum Engine & Drivetrain
    Last Post: 12th June 2011, 17:59
  3. Steering pump/ reservoir
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2009, 20:04
  4. Empty Washer reservoir warning
    By CooLix in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2008, 18:00
vacuum reservoir insignia
vectra c vacuum reservoir
vacuum reservoir vectra C 1.9cdti
insignia vacuum reservoir
vectra c vacuum bypass
insignia vacuum problems
vectra cdti vacuum pump
location of vacuum tank vauxhall insignia
vacuum joins vectra c
vacuum reservoir insignia price
