Thread: Handbrake Light / Switch
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Handbrake Light / Switch
    Hey peeps,
    I noticed last week my handbrake light was taking a few seconds to light up after applying the handbrake, but this morning it won't go out at all!!! I've driven for two hours with it on!
    I'm guessing the switch needs a clean, does anyone know where the switch location is and how to get to it? I'm guessing it's at the back of the lever??
    11 Post(s)
    Handbrake light also is the low brake/clutch fluid warning light.
    Have you checked the level is ok and not low?
    First place I would be looking.
    Apr 2009
    Stevenage, Herts
    Good shout as didn't know that. Just looked and yeah it's just on the "min" mark, luckily got some dot4 at home (bought for my motorbike clutch).
    All my pads are new (changed all of them last November) and looking they've still got loads of life in them, wonder why the level has dropped?
    11 Post(s)
    Keep a regular eye on the level. You might have a leak. Also look around the calipers and brake unions to see if there are any damp patches.
    Also the clutch uses the same reservoir. I take it you've not noticed any recent clutch problems?
    West
    this is a common occurrence once the pads have worn in properly
    Apr 2009
    Stevenage, Herts
    Hey, topped it up this morning and the light is out. I've not noticed the clutch change at all, I'll keep an eye on it and see if it moves. I had a Frontera once that the first time I ever looked at the clutch reservoir i noticed it was empty!! Again didn't make a difference to the clutch feel at all once filled up!
    Cheers for the advice!
  1. Handbrake light on when its off!
    By SlowCoach in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2013, 10:46
  2. handbrake light problem
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2011, 22:55
  3. Handbrake switch wiring
    By StephNET in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2011, 05:38
  4. handbrake switch
    By Dazzy2006 in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2010, 20:32
  5. Handbrake warning light
    By dh.dti in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2008, 09:49
vectra c handbrake switch location
hand brake switch vectra c
handbrake light switch vectra c
