Thread: 2004 Signum radio removal
    Feb 2011
    Kent
    Unhappy 2004 Signum radio removal
    Hi,
    I am desperately trying to remove the head-unit from the signum Elite CTDi that I've just purchased. I want to fit a Parrot bluetooth kit but can't get the ****** raio out...
    I've bought the Halfords radio removal tool kit (two wires that I could've made from a coathanger!) but the radio aint budging! The wires go in, click etc. but no amount of pulling removes the radio - in fact, the tools eventually slip and I end up swearing a lot!
    So far, I've removed the glovebox, heater vents, climate control, dash trim, broken the front off of the radio (will sort that later!) the central console trim etc... I can get my hands all around the radio but no matter what I do, I can't even slightly dislodge it.
    Does anyone know if there are any hidden screws/bolts holding this thing in? - I suppose I could always leave the car unlocked on a local council estate... I'm sure the radio would be gone within minutes!
    Daran.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    When I tried removing mine I found I wasn't pushing the pins in far enough.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    sure this will do the job http://cgi.ebay.co.uk/JCB-BEAVER-BRE...ht_5949wt_1139 sorry in a funny mood the day
    WGAF#5
    take out the tray under the radio and pull out the fan control facia- this will also allow you to get your hand behind to give it some assistance
    Feb 2011
    Kent
    thanks but i've already tried that... got the climate controls removed, the heating vents from above, the glovebox from the left...
    Feb 2011
    Kent
    Finally got it out - used a screwdriver to dig the cage out at each corner... can't believe those poxy little spring clips were actually holding it in so securely.
  1. radio probs 2.0dti 2004
    By japaul in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2012, 11:32
  2. 2004 Y20DTH headlights, instrumt lights, radio, airco,.. flickering !
    By The_Dutchman in forum Vectra C / Signum Troubleshooting
    Last Post: 18th December 2011, 13:57
  3. Central Dashboard Display & Radio cut out / reset problem: 2004 Vectra 1.8
    By mikethemechanic in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2011, 14:34
  4. Replacement radio for 2004 Signum - Suggestions
    By rowladar in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2011, 15:06
  5. Radio Removal
    By Image2000uk in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2009, 23:26
