Results 1 to 10 of 16
Thread: Spanner light :(
    Feb 2011
    South Wales
    Vehicle : AUDI
    Trim : A5
    Engine : 2.0 TDI
    Year : 10
    Question Spanner light :(
    Ok, after searching and googling and turning the engine off and on a tiring amount of times... Im looking for some second opinions!
    The spanner light comes on when the car revs to 3500 in 3rd or above, i can redline in first and second!? After the light comes on its in a limp mode until i turn off and on again...
    Having searched and googled ive come up with the following assumtpions of what it could be??
    Gunk?
    Boost sensor
    Crankshaft sensor
    Camshaft sensor
    Egr valve
    So confused about this as half the abbreviations used here dont exist on my old car (saxo)
    So if anyone has any suggestions i would like to hear
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    What engine is it etc? will prob help narrow it down a bit. If its 2.2 direct petrol could be fuel pump or fuel regulator problems which are common.....
    Feb 2011
    South Wales
    Vehicle : AUDI
    Trim : A5
    Engine : 2.0 TDI
    Year : 10
    Sorry my bad there, expected the site to put model under avatar...
    Its 1.9 cdti 120
    Dec 2010
    Boosting in W.Mids
    Trim : Aero
    Mileage : 62000
    Could it be that you need to clean your egr, boost control vavle etc. They get rather gunked up with soot etc. Also check your swirl plates on the manifold. Not 100% on cdti engine but im sure someone will be along to correct me lol.
    But start with the cheap diy jobs dude.
    scottish region
    dont think its egr as it should not go in to limp mode
    Regular Member badback's Avatar
    Runcorn
    Don't think the 120 has the swirl flap problems, just the 150.
    Feb 2011
    South Wales
    Vehicle : AUDI
    Trim : A5
    Engine : 2.0 TDI
    Year : 10
    Hmmm, if we can rule out the EGR, then when I get chance ill have to get the carb cleaner out and clean up the sensors on the inlet.. as you mentioned, nice easy DIY jobbies..
    Feb 2011
    South Wales
    Vehicle : AUDI
    Trim : A5
    Engine : 2.0 TDI
    Year : 10
    Cleaned EGR and spanner is still coming on at 4k ish revs...
    Feb 2011
    South Wales
    Vehicle : AUDI
    Trim : A5
    Engine : 2.0 TDI
    Year : 10
    Ok so i understand that there is a variable vane turbo buried in that emgine bay...
    I have been reccomended using a turbo cleaning kit made by innotec by a local mechanic? As the fault is overboosting and the product says that it can solve seized turbo vanes? Anyone had any experienxe with this?
    Nov 2010
    *!dave!* - The Black Country
    Spanner light is an emmission error indicator
    I would suggest you do NOTHING until such time as correct diagnostic equipment is used to interigate the fault stored
    Do not waste your money on lotions and potions until you know why the light is on
    Any good diagnostic bod should be able to read the codes but a simple code reader is not suitable as the Vaux system is a specific system and not a generic all makes and models set of codes as per OBD etc
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
code 84 spanner and management light on and limp mode
