Results 1 to 10 of 23
Thread: Poss Boost Control Valve Problem
    Nov 2010
    *!dave!* - The Black Country
    Default Poss Boost Control Valve Problem
    (Have searched many "No Boost" threads but none seemed to cover my problem)
    Vectra 56 Plate
    1.9 CDTi
    150hp
    62,000 miles
    Has had (gen Vx new) :
    modified inlet "swirl" manifold
    EGR valve
    Cam belt kit
    Water pump
    No fault codes present or warning lights
    Starts and runs lovely everytime
    No audiable boost leaks or visible split hoses
    Small vac pipes all good
    Removed turbo to inspect
    No end float or off centre rotation
    vacum actuator holds suction and actuator arm moves fine
    no signs of bearing seals worn and not "sooted" up
    Car drives fine no misfires or juddering - Simply no boost - it drives like a Non-Turbo diesel
    Using a Bosch KTS650 I can live read the engine parameters and only real reading of concern is Boost Controller operating Range - It only varies between 75% - 55% operating range
    Max boost achieved is 120kpa (97 kpa = atmospheric pressure 1 bar)
    Max nominal boost = apprx 175 kpa
    My theory is boost controller is holding back the vacum to the actuator when it should be letting engine use the max boost produced until near over boost let back off the pressure
    AM I MISSING SOMETHING - HELP !
    Nov 2010
    sorry lads / lasses just realised this is my first post
    little introduction
    I love Old Fords especially MKII RS2000 Escorts - lol
    Self employed mechanic and MOT tester
    Have done more than a few inlet manifolds on 150 horse vectras
    The above car came in as a non runner and a boot full of New VX Parts as listed above
    (I just provided the labour)
    Customer complained of no power BEFORE it became a non runner and then delivered to me
    PRESTON
    I guess you have also cleaned the boost sensor in the manifold? Have you checked that there is ample vacuum from the vac pump? I had an issue on mine where there wasnt enough vacuum, changed the vac pump and everything spooled up as it should. It hadnt totally failed, (although the small vac pipe from the pump was full of oil), as brakes still worked, but, after the new pump fitted, brakes were way better too.
    Nov 2010
    Quote Originally Posted by barney490 View Post
    Boost sensor had more acne on it than a 13 year old school boy but all clean now and all the resistance readings listed on Autodata are within spec
    With engine running remove boost sensor connector and spanner light comes on - refit light goes out (then clear fault memory with Bosch unit)
    Vac pump being mechanical obviously give no warning lamps but I do have a vac gauge so what vac should I expect also do vac pumps have an inlet filter as this may be blocked !
    note:- brakes still have servo assistance and feel fine
    PRESTON
    Not sure of the vac reading they produce, i had none at all at the small connector and as far as i am aware they dont have an inlet filter. I have heard of a couple of other instances where it was the boost valve on the slam panel causing issues by not holding vac and when changed, all was good.
    Nov 2010
    To be fair the vac produced does seem ok but what if I bypass the boost valve and go from vac pump to actuator pipe ?
    This would then eliminate the boost valve completely
    Or would this not work !
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    We,(I), want pics of your old skool fords MKII's were what I grew up on
    Nov 2010
    You just had to didnt you - lol (ask for pics)
    I run a website - www.rallyesportescorts.co.uk in my "spare" time
    Regular Member Mopar Man's Avatar
    Jan 2011
    herts
    Nice
    Nov 2010
    Quote Originally Posted by Mopar Man View Post
    Nice
    cheeRS but I really need help with this boost starved Vectra - lol
  1. z20net boost control valve sensor
    By dj1 in forum Engine & Drivetrain
    Last Post: 25th April 2012, 13:31
  2. Turbo Boost Control Valve?
    By stupottyuk in forum Engine & Drivetrain
    Last Post: 20th July 2010, 12:59
  3. Climate Control - poss retro fit???
    By DaveyVXT in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2009, 21:50
  4. Heater problem with air direction, poss canbus?
    By Wild al in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2008, 23:30
poss in boost
how to clean dpf filter zafira
