Thread: HID's Bulb Location
    Full Member
    South West
    Default HID's Bulb Location
    After fitting HID's nearly 6 months ago, i couldnt really see what all the fuss was about to start with, yeah it made things a bit brighter, but the beam seemed to be very short compared to the original bulbs.
    I have just been out and turned my bulbs through 180 degress as suggested in a post yesterday...
    Now i see why everyone likes HID's so much...!
    Ok, so i am not the sharpest tool in the workshop... just a tool in this instance!
    Regular Member TomiboyC's Avatar
    Aug 2007
    East Ayrshire
    haven't had time to look at mine aidi so hopefully i might have done the same as you
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Did you put the bar thing at the top or bottom?
    Woodbridge
    It was something to do with reflection, So I guess the bar is meant to be at the bottom.
    Full Member
    South West
    They are towards the bottom of the holder.
    When i orginally fitted them, my local garage did the alignment for me.. and i used Duncans method of setting them low on the switch... I think on the high position they are going to be like main beams at the moment!
    Aug 2010
    York
    cheers
    PRESTON
    I thought H7 bulbs would only fit one way round as they have a flat on them that lines up with the holder.
    Full Member
    South West
    i think you are spot on mate... I think when i put mine in they were sort of located correctly, but i was probably a bit ginger with pushing them in... I have actually moved them around, as the black wire is now at the top where as before it was the red at the top (or the other way around, i cant remember)
    So they could have been located in the correct way, just not pushed home all the way, and at an angle where the beam pointed down more than straight forward.
    Woodbridge
    Might have to have a look. But I think mine are ok
  1. fao EVERYONE with HID's
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 06:44
  2. HID's Direct 'MTEC' bulb life?
    Last Post: 6th November 2010, 22:20
  3. Hid's Fitted Today... Ballast Location / Pre Face
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2010, 22:48
  4. Can I Replace Fog light Bulb for a 100 watt Bulb
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 19:33
